Stay away from ebay when needing a coupler
icleancarpetz
Rafael Samson
Ebay is a dumping ground for old expired stock. These couplers have a shelf life of 5-8 years acording to the manufacture. Anything after that the components can degrade / dry rot.
If listing has no box, DONT BUY! most likely old stock. I would not buy off of ebay regardless if in original updated box. Might have been bait n switch. How do i know? Live and learn the hard way when doing a job and your machine clunks out because coupler failer.
Buy direct or reputable distributor
Ebay dump. Fortunately lasted thru the job when i spotted it.
Wondered why they failed throughout the years while on a job. Dry rot dump from ebay.
Hawaii
I bought a chinese coupler off Amazon for $18. I know you don't like Bezos and to buy local, well the slant eye coupler is still going.. I did run my old LoveJoy with a rip in it for longer than I should have but it did work..
I do appreciate you sharing the advice!
Liverpool
Will Phillips
Years of Experience
30
Role
Business Owner
Let me guess Chemtex Panther? the coupling sleeve needs to be perfectly aligned and the little nuts need to be tight as.
KevinD
Binghamton,New York
Kevin Dumas
A quick check with a infrared thermometer on the flange closest to the engine will show you why a lot of couplers fail prematurely. The radiant temperature transferring to the coupler from the engine and sometimes the exhaust is way beyond the 250-275 degree limitations of epdm coupler sleeves.
