100% VLM ???
SteamwayPro
George
George,
What is your process for removing candle wax?
I use a Namco Steamer to heat up and soften up and loosen the wax. Then use a drill brush or scraper to scrap wax off carpet
Never a problem getting wax off carpet but sometimes the red stain from red wax can be a problem
Need to use red stain remover for that but sometimes still very difficult to get the red out
I also have a Wagner Wall Paper Steamer, that can be used on wax or red stains, but it never gets out of my basement
Only problem with Namco Steamer is they don't last. They usually stop working after 2-3 years and yes I use distilled water in them
That is a picture of Namco Steamer removing Red Stains
Dry volatile solvent after scraping the top layer of candle wax of for the win. You're welcome
Scrape the blob regardless of size. Bone scraper. Dry volatile on a towel and go to town. Catholics go crazy with wax!
Reactions: frank fratto
frank fratto
frank fratto
Obviously you haven't run a cimex. I wouldn't run in residential, so it probably wouldn't be beneficial for you. It is the king of agitation!
Cimex.
I have, I've never owned one. { it was very efficient]
50% of commercial it would work well.
The 175 will not break down.
you can use it in tight areas
you can use it in open areas.
use it in homes
you can carry it
Plus, i'm a pad man [commercial or house-- Pads all the way!]
frank fratto
frank fratto
I love that steamer
No need for that with a cimex. Don't get me wrong, I've stripped
thousands of ft with a 175, 13, 15, 17, 20 inches. Tanks and no tanks.
I've used em to scrub carpet with the brush. It is versatile for sure. I couldn't be without one, or two.
frank fratto
frank fratto
You can't beat the cost$$$
And that you can take 175 and use it anywhere and everywhere.
And by chance if it breaks down,
You can run to Home Depot and rent one for next to nothing.
I'm just saying???
Not for nothing,
but
IT IS THE BEST MACHINE OUT THERE!!!!
bmxin
dayvaad
Just Wondering
Am I the only Member here that uses the VLM Method on every Carpet Cleaning job
Commercial and Residential
It's time to come out of the VLM Closet
No HWE with TM or Portable
100% VLM with 175 or OP
I switched to the VLM Method in 2019 after 25 years of HWE
And it was one of the BEST decisions I have ever made !!!
I love VLM !!!
I'm doing VLM exclusively for 2 weeks now and probably another month while Prochem&Van is being rebuilt.
For the maintained homes where I know it was flushed(by myself) it's an easy pad/padcap.
However for commercial I'm using a hybrid system by pretreating with enzymes/citrus/changing out pads/applying 2-3 acid rinse padded, then finish with extraction via electric machine(Mytee)
You don't have to be an absolute to one cleaning discipline as you can fit hwe, VLM, porty all in one standard size TM van.
I've had good referrals as flushing urine out for those customers who use VLM franchise. I'm actually really looking forward to my refreshed/new to me setup TM. Also with my new HX's, 350psi 3 Flow, and 45 blower I've always had 90minute dry times...
I've also had fun on 500' hose runs with the 2.5"/100' performance hack upgrade.
frank fratto
frank fratto
Nothing wrong with steam cleaning then VLM !!! That WORKS and WORKS Well !!!
Reactions: bmxin
SteamwayPro
George
Frank
Do you use Bonnet Pro Ironman Bonnets on your 175 to extract
They're made for 175's but work on OP's. I only use them on nasty carpet. They really pull out dirt and grab carpet
I use a CRB to scrub. I guess you use a brush
What bonnets do you use
What vacuum do you use
Life is BETTER using the VLM Method !!!
frank fratto
frank fratto
Frank
I do have Iron man pads, very rarely, do i use them. [ they work Great]
I scrub most of the time with white or red pads [They hold so much SOIL]
once in a while green pads for" Rat Nasties"
sometimes i use my shampoo brush.
I love my baby blue MICROFIBER pads!!! {for extraction]
They hold an unbelievable amount of soil!!! { Did I say UNBELIEVABLE]
Plus they are so easy to clean in the wash!
I do have a CRB ,I use it on tile.
Mostly, the Bissell commercial 12and 16 inch {Sanitaire}
Sometimes i pull out the Kirby G5
SteamwayPro
George
When I first started experimenting with VLM back in 2012 I used a 13'' Hawk 175-300 Rotary
I do a lot of Rentals so usually no customers around and that gave me a chance to work on the Method
I used a brush to scrub then Cotton Bonnet to extract
Have you ever tried Bonnet Pros Multi Brush. You can put a Fiber Pad or Bonnet in the middle
The biggest problem with rotaries are the small wheels. Not fun carrying them up and down stairs
frank fratto
frank fratto
Small wheels for sure!!
SteamwayPro
George
The new 13'' Swirly has a 1.5 motor but still only weighs around 85 pounds without the sprayer
What machine are you using now
SteamwayPro
George
I'm a Equipment WHORE
And have considered buying the Swirly
I was a HWE WHORE and now I'm a VLM WHORE
I'm always looking for a BETTER Way and FASTER Way to clean carpet
SteamwayPro
George
I have jokingly, for years, postulated that carpet cleaners are some of the biggest suckered out there.
I ought to know!🤪
I love my job and love cleaning carpet
And I love my customers. The people that pay me money to do the job I love
Can't imagine going to work every day to a job that I hate and that's boring
Life is Good !!!
frank fratto
frank fratto
If I'm climbing stairs, it's 13 inch Clarke or 13 inch Hild { I have 3 of each}
Sometimes i will take the 17 inch up????
If they would redesign the 13 inch Swirly I would buy it ,because it would be shiny and New!!!
One horse power motor- shorter handle.
I do not need a chemical tank on it.
Dwell time is much too Important,
need to per-spray before cleaning....
YES ,LIFE IS GOOD!!!!
frank fratto
frank fratto
frank fratto
frank fratto
Don't you love it when your customer cancels at the last minute, and
you really don't care because you've been so busy!
LIFE IS GOOD!!!
Latest Auctions
