feel free to use this on your pages...
Scrubbing brings up images of scratches
Job for the crb.Scrubbing brings up images of scratches
Yeah...not YOU.Thanks. Ill do that
Now I have a weird image in my head.Scrubbing brings up images of scratches
A blank one that wont be obviously the same as yours on your page?Yeah...not YOU.
Good picture
What cleaning solution are you using? No need to rinse/neutralize?
Used Simix on this job pictured....commercial job... Dont usually see residential that bad... Like TLC (Trinity Neutral Cleaner) on residential.What cleaning solution are you using? No need to rinse/neutralize?
I always liked to prevac with a backpack vac with a horsehair head tooGrout poll brushes, deck brushes, wire tooth brushes for when all other brush bristles are too fat, knee pads, and lots of towels are a must for heavy soiling conditions.
So far I've found Saiger Tsunami to be the most effective on extreme soiling. Common no rinse neutral cleaners work great everywhere but heavy use kitchen settings.
The teflon glided Dev12 at 600 psi has been my fave rinsing tool. Brush rings on a 14 swivel HS tools create that walking a blind dog feeling that drives me nuts. A pre sweeping with a fringed micro flat mop is VERY important to collect grit and crud, especially rocks and small bits, screws, nails etc that may get stuck in the glide and damage the vinyl
AmazonI've used simix before that someone had. where do you pick it up from?
