Best method for drying
Sergio
Italy
Sergio
Hi,
I bought a garage to wash the carpets. For now I can't buy a centrifuge. I will dry the carpets by vacuuming them with a vacuum cleaner for liquids. After vacuuming the water, I will place the carpet on a flat floor for final drying. What type of flooring do you recommend for this phase?
Thanks
Oh man. Where to start......
If you are forced to dry on a floor and don’t have a rug rack or lift system, I would build a floating floor to dry the rugs from the back to prevent browning. Use an acid rinse.
At the very minimum lay down a tarp and float the rug with air movers by placing them under the rugs.
