Bubble in rubber floor
Contact cement through a syringe?
Anyone know a good proven fix?
IMG_20200324_132321.jpgIMG_20200324_132356.jpgIMG_20200324_132406.jpgIMG_20200324_132339.jpg
Did the high heat from the 650 cause that rubber to bubble up?
Andy
Doesn't Matter
Unless that is some really thin flooring those small bubbles wouldn't be from an adhesion issue. They look more like blisters caused by some cleaner that had been used on it. If it is a laminated type flooring, the top layer is starting to come loose from the bottom.
That's possible, 99% of the bubbles are in one area
