Remind me, what is an AquaTech?I do on my AquaTech, but not on the Butler unit. Jim says there shafts are self centreing.
A cleanco knockoffRemind me, what is an AquaTech?
A cleanco knockoff
It was the trailers fault!Are you able to check to see if your vac gauge is accurate? My gauge crapped on me and It was off about 4hg. I had it set at 18-19 and it showed 14 on the gauge. I thought the blower was causing the bogging down when it was just the gauge and vac relief
Belts slipping.....rough up the edges with some course sandpaper
It would......however each time I've mentioned it.....people act like I got three eyes.....Actually that in it self would be a great learning post -So anyone ever use masking tape to determine the clearance when installing the clutch or jus laugh at my dumb idea?
The first tm I operated was a steam genie slide in. That was the late 70's. I switched companies and we had some very well used cleanco units. There was a lot of smallercompanies then putting out pto machines. Jem, pumps and power, cleanco,aquatech. I may be wrong but I think cleanco was first. I remember them advertising doing a hose run to the top of the cn tower. I don't know how well that workedisn't that backwards? At least for the compact. Then later cleanco bought aquatech?
*i don't actually have any idea but thats what I've heard/read
Joe Rorke was instrumental in the development of the modern Cleanco. It's a direct copy of the Aquatech. Joe Rorke and Jim Miller were the go to guys locally in the development of pto truck mounts in the seventies and eighties. Jim has passed away, last I heard of Joe, he was living in Okotoks Alberta.A cleanco knockoff
Other way aroundA cleanco knockoff
That bogging down always sounds likFilters clean?
Damn....I jus know theres a punchline for that.....See? I don't know my ass from a hole in the ground.
Ya but I'm sure he told the captain how to get thereSounds far away
