DuraStone...?
Andy
Doesn't Matter
Durastone is a combination of vinyl and stone. Adhered to the floor with pressure sensitive adhesive, much like carpet tiles. Liken it to LVT but I believe that it can also chip. A retailer I knew quit carrying it for that reason. I have never cleaned it but would consider using CRB and spinner with pressure turned down.
Hack Attack
Dan
I think that might be what I looked at today? thought it was stone at first, no experience so following
sweendogg
David Sweeney
As mentioned above, Durastone was the precursor to today's LVT. It could be installed with our with out a urethane type grout. Your procedures above are spot on. Biggest thing they mention in their care instructions were staying away from strong solvents or any citrus cleaners as it will break down the grout if present and the adhesives. While definitely not needed, some people have been known to put down sealers over them. :hopeless:
Andy
Doesn't Matter
It also makes it more firm. Ever see the button marks from the bottom of kitchen chairs on linoleum or someone walking across it with spike high heels?
Reactions: Mike Pailliotet
Believe it or not, one of my elementary schools has that in their cafeteria. 21 round tables with 8chairs around each. Yes I said elementary. Architects will sell anything, to anyone.
todg
Michael Marcus
Great for the exterior! Inside, good luck and God bless!
good gravy, turns out it was this crap...
DAT
Bill Cheryl
I see those everywhere, but it is used exterior...the one you cleaning is in the house? On what?
Acp
Bjorn Marshall
http://acstone.com/all-products/all-products/dura-stone/
Honestly, I dont know if I've cleaned this product.
I have a request to now..
I imagine the adhesive is the only concern, assuming its not been topically coated.
Neutral pH, CRB, low pressure, low heat rinse?
That is just another company offering basically an epoxy based product with different types of aggregate added.
Stone coat, dura stone, elite crete, etc they all have very similar systems for commerical and residential applications. I got certified for installation, its was a 3 day hands on course we poured like 100 different types of flooring for all sorts of applications like garages, showers, residential flooring, pool decks, etc. .
you will not hurt the epoxy by cleaning it, once its fully cured (at least with the manufacturer we use) the product is 8x the strength of concrete.
its very much bulletproof, in the class we took hammers to cured surfaces to try and destroy its amazing what it can handle. We also set a counter top on fire, boiling pots straight from a stove burner etc.
Acp
Bjorn Marshall
they do sell cheap homeowners ones at home depot, and yes they probably dont last.
idk specifically about dura stone but what we worked with is extremely durable and has been installed in firehouse garages, airplane hangers, etc
tensil strength of one particular coating was over 15,000lbs per sq in
