sassyotto
- Jun 7, 2013
- Name
- Paul
Going to order one tomorrow. Need advice.
Titan 575 using it mostly for commercial work. Right handed
Should I go with
13 inch or 15 inch? Reason I ask is that 13 inch has 5 jets and 15 inch has 6. wouldnt the 13 inch leave the carpet drier since your using less water (one less jet) and it has a smaller footprint to draw water from so the TM vacuum is more effective.
Left hand or right hand trigger setup? I know I can switch it but may as well order it knowing that is probably the way I will use it.
Any other suggestions appreciate.
Yes I will get the tall boy handle and hybrid glide extras.
THANK YOU!
Should I go with
THANK YOU!
