Chris Muetterties said:Why not bring a Nick-o-Shit to Myteefest so we can run it next to the Judson ?
Garcia,Mr Chavez(just in case you did not know,that is Gringo for thanksRCTPKS said:That's a good deal as long as you're willing to take the risk of going with a small builder.
To me that risk is magnified for a guy on a budget.
I can make a bad decision on a purchase of a machine or piece of equipment and survive it. I'll be pissed, but more at myself for trying to save a dime and believing some hype.
A guy that has limited funds had better do a much better job of researching their purchase. If you blow it and buy a new model or an untested machine or piece of equipment, it could be a knock out punch.
That's not saying don't buy a Nickomatic, just don't listen to the hype. Research it yourself, see one operate and talk with those that own one, then make an educated decision.
Mikey P said:lots but I'm also gonna piss of a customer and loose a half day or more dealing with something most every other TM does not have issue with so why bother?
SO MANY other, wiser choices to be had.
James Cooper said:[quote="Chris Muetterties":3e4yxvze]Why not bring a Nick-o-Shit to Myteefest so we can run it next to the Judson ?
Chris Muetterties said:[quote="James Cooper":3qa11hfc][quote="Chris Muetterties":3qa11hfc]Why not bring a Nick-o-Shit to Myteefest so we can run it next to the Judson ?
Chris Muetterties said:Performance between what ?
Lets say you took a simple formula like 1 cleaning pass and 1 dry stroke with that same vac and pressure hose.
Yes their would be a difference.
Now if you want to say that a Nick-o-Shit with 3 cleaning strokes and 4 dry strokes will do the same as an ElDiablo with 1 clean and 2 dry you might be right.
But since Labor is the highest cost of doing business there is no way that their performance is the same.
The other factor is when a Tech or an O/O gets busy say with a Nick-o-Shit they will start cutting out the extra strokes to save time because they priced themselves too cheap or the Techs commission is dropping.
Kevin P said:James,I have to tell you having outstanding heat DOES make a difference in my world.I have had 8 different setups over the years,that was my testing ground.
