heat Exchanger
Hooked on
Callahan florida
Justin laurendine
I just started a carpet cleaning business and I have a problem that I need some help with. My coolant in my van is overflowing does anyone have any ideas on what the problem could be. Like I said I’m new to all of this and am heavily invested into this and must find the problem and must have a solution quick as I have jobs lined up. CDS overdrive 4.8 hydramaster I believe it’s a 2006
the title of this thread?
and I seem to remember somebody with the issue getting by for a bit using alumaseal....but that probably isn't a good idea
found it
**heat exchanger still ended up being replaced
Reactions: Living The Dream
scotty747
I bypassed mine and added an oil fired heater. Not cause they were leaking, they just didn't put out enough heat. You may be able to rent one until you fix your heat exchangers.
