How are you vacuuming out your blower oil?
I use this. Got it at Harbor Freight and charge it up with the air compressor. Does an excellent job. It was a good purchase.
Jim Morrison
Canada
jim
I use a pump up extractor like the one you posted Mike. Works great, the layout of the Cleanco's drains make it slow as molasses otherwise.
La Canada, Ca
La Canada Carpet Cleaning
Get the amazon one, I have it kicks ass for 650 blower and pump, Pump is a PITA WITHOUT.. Also can use on engine, huge time saver...You'll love it
dealtimeman
Everyday is Saturday.
Fort Worth , Texas
Michael
I would strongly encourage all who use this quick valve to install a plug at the end Hose attached to this drain valve. Always fill oil including hose to level, yes I know go ahead and waste a little oil it will be cheaper.
Reactions: Lee Stockwell
Benton KY USA
I've heard of several inadvertent draining incidents that killed blowers or pumps.
I seriously think the draining issue is not needed very often, if at all.
How often do you drain or change the oil in your differential?
KevinD
Binghamton,New York
Kevin Dumas
I agree. We are not talking internal combustion engines where the oil gets contaminated. I usually put synthetic blower oil in them and never touch them for 5-6000 hours except to check the glass sight gauges for proper oil level.
