Insulating/sound supressing new van interior.
Papa John
Lifetime Supportive Member
San Francisco, CA.
John Stewart
Is the the stuff i should use on walls and ceiling?
Ill be Rino lining the floor and up 10 inches on wheel wheels and walls.
Shane T
Waukesha, WI
Shane Tiegs
What sound are you trying to reduce? It will do a good job of insulating but I don't think you will notice any noise reduction. Will you also install carpeted panels?
Papa John
San Francisco, CA.
John Stewart
I figure the TM sound will vibrate less off insulated walls then bare metal. I might add carpet as well.
Reactions: Shane T
Rob Grady
Sauble Beach, Ontario
Rob Grady
Do as Justin said. I have used Great Stuff, but only to fill gaps around wheelwell and side walls. I also use it to fill in the cavities on lower rockers to inhibit rust on my older vans. Does a good enough job, but you cannot tell if there is 100% coverage.
You would need to buy several cases and it would look like hexxhockey sticks.
