https://brodysdrykc.com/residential...between-the-cracks-dont-leave-out-your-grout/
Is your deep-cleaning falling between the cracks? Don’t leave out your grout!
How long has it been since you’ve had your grout and tile floors and surfaces professionally cleaned? If you’re like most of us, the answer is “grout and tile should be cleaned by a professional? I had no idea!” The truth is, the grout and tile in your home take a beating on a daily basis, and if not properly maintained they can be one of the most expensive surfaces in your home to replace. While you can take a DIY approach by purchasing tools and cleaners at your local hardware store, hiring a professional is always the best option. Here’s a few reasons why:
Carpet cleaning machines are usually not powerful enough to provide the high-pressure steam required to properly clean and sanitize hard surfaces, and if a steam cleaning professional does not change out equipment heads and drain water between cleaning the carpets and cleaning your hard surfaces, dirt and germs from your carpet can be spread to your countertops and shower—yuck! Brody’s Dry uses separate machines specifically designed to clean the type of surface, so you can be confident your hard surfaces are clean and dry before we say goodbye!
- Your body will thank you for it. Grout and tile cover a lot of surface area. Trying to scrub down large areas of tile and grout can take multiple days and be extremely tiresome. Because DIY products are typically applied by hand, multiple hours spent on your hands and knees can be extremely damaging to your joints and back. Also, spending hours inhaling the noxious cleaning products usually sold at stores can be harmful to your lungs and cause breathing issues for you and your family. Hiring Brody’s Dry to clean your tile takes only an hour or two of your time.
- Your friends will thank you for it. Most DIY products require a certain waiting period before the cleaned area can be used. After a long, hard day of DIY cleaning with harsh-smelling chemicals, the thought of not being able to take a shower or walk into the bathrooms for 24 to 28 hours might make you cringe. And you’ll probably smell a little rank if you choose to do anything social during the process–trust us on this one. After a Brody’s Dry clean, your surfaces will be usable in 15 minutes or less!
- Your home will thank you for it. Our patented HOST Dry Extraction System is a simple, safe and extremely effective method for deep cleaning your grout and tile without getting it wet. Unlike many steam cleaning carpet companies that use the same tools to clean carpets and tile (Ewwww), we use tools specifically designed for your hard surfaces. Our counter-rotating brushes gently scrub tile and grout to dislodge dirt and grease. The HOST extractor sponges contain a balanced blend of water, detergents and natural ingredients to absorb any additional residue. Because our cleaning blend does not contain harsh chemicals, no noxious fumes are emitted during the process. Because there is no residue left behind and floors are dry quickly, floors stay cleaner for a much longer duration.
I say a lot of shit.
