Namco beast?
Carpet911
Wi
John jenkins
Hey all, just about ready to purchase a portable unit and was pretty set on a nautilus extreme, an opportunity has come up to buy a new namco beast. Both are like 4K. Dosent seem to be much info on the beast anywhere. A body have experience with these two units?
this thing?
  • 4 - Two large stage motors that produce 300" of water lift
  • 500 P.S.I. Pump / 100 P.S.I. Pump
  • A single 12 AG / 25 ft power cord
  • 16 gal waste tank
  • 12' stainless steel wand
  • Chemical Applicator
  • 100' Solution hose
  • 100' 1/2" Vacuum hose
  • Start up chemicals
don't know anything about them.
Maybe one of the porty guys can tell us how it runs four 2-stage vacs and 500psi pump on one cord ....without tripping breakers
seems like an awful lot on one cord
Probably a 220 volt cord. You will have to plug into a dryer outlet. No solution tank that I see. Probably connects a hose directly to the pump.
Carpet911
Wi
John jenkins
It’s a little industrial looking, but the little bit of info you can find seems people like them. The company gives very little info which is off putting
probably a good machine for what it does. You have to make sure it meets your purposes. If there is no solution tank, you have to hook up a hose on every job. Newer homes and condos today often have faucets without aerators that you can put a tap adapter on. The good thing with those machine is they go up and down stairs easily. They have different vacuum and pump configurations.
Can your you set the travel to 7/3/85?
are you trying to say "Sherman, set the wayback machine" ?
lta
