Question
Arizona
If I am running the gauge on the left up to 1500 rpms
About what should the gauge on the right be reading??
also.....is there a reason why theses are not liquid filled
You have 3 gauges to the right of the RPMs Jim...
What one are you concerned about?
If you mean the far right that gauge measures your inches in lift and would depend on how much hose you have hooked up and what the tool hooked to it is doing. If you were to capped both ports off 100% then at 1500 RPMs it should read 15" to 17" depending on how tight you have your vac relief set.
I have mine set to 19" so that it runs at 17" with both wands on the carpet.
Arizona
Sorry I thought the one on the right went hand in hand with the one on the left
It's right on the money buy your #'s Thanks
I thought that this may be the water in the hose problem but That rules it out.....
The Analog gauge just to the right of the RPM guage is your water temp as it leaves the upper Zen HX...
The Digi gauge below it tells you and controls the Oil temp.
Use the tiny Set button to set the highest º you want the oil to get.
I set mine to 300º
