Recommend a spot machine for customer
alazo1
I have a customer that is looking for a decent spot machine. His budget is $300.00. He bought a green machine (this is not the name but close) and thought it was junk.
Any ideas?.
thanks,
Albert
he's probably going to need to spend a few more bucks with shipping , Albert
the EDIC Bravo machine is good one that's very close to his budget.
I got one years ago for a custy with old/sick dog problems.
http://www.***************/store/edic-b ... -4830.html
The dog is gone now, but the machine is still working well.
he uses it now to clean his motor home and vehicles ( I charge a FORTUNE to clean them) cause i HATE cleaning them.
and the occasional spill/spot in their home between our regularly scheduled cleanings
shortly after I sold it to him, I had to tighten the nylon hose barb fittings on the pump cause they were leaking.
But other than that, it's been a great little spotting machine
I have one of these Mytee spotters and have gotten two for my pet owing clients.
3 thumbs up.
fastlanemwd-store_2022_65830314
wow, a few design changes and getting rid of unnecessary components and Mytee could make fine 3 gal corded electric sprayer out of that
instead of working on a sprayer the size of a small porty....
are you reading this John L??
For $399 you are gonna be hard pressed to outperform the Tempo by Mytee.
As most have found out with "cheaper" machines, there is a minimum perfromance you want a customer to have, and you aren't going to get it with a cheaper vac motor, or pump, the Tempo has what you want your customer to have.
John Labarbera had a special on these awhile back, you may ask him to run a special again, then buy a couple for your peeps, if not your own truck.
