Technically speaking………………
Cameron1
and without using the words, “oxygen bleach, chemical, or oxidizer how would you explain to your client the process and procedure of using osr to treat Urine. Just curious
I don't. I just do it and get paid.
If you gotta explain it, then you're not very well respected by your "client."
Steve, I wouldn't, I'd just use some Quat-a-lot and forget about it, follow with some O2 pre-spray and get rid of the yellow in the process.
OSR is so 2000.....lol
Steve;
The best solution is to saturate the area with:
1. An Oxidizer (which breaks down the urine deposits so they no longer release odors)
and
2. a oxygen-compatible actual Enzyme
Extract with claw and then DynaCide or HydroCide or another "Cide" type product.
Larry
Jesse
Cleaning the pad and backing?
Maybe add "as best as we can from above"?
I try to answer technical questions with just a smile or a comment like Gary made
Oxidizers like OSR and Pet ZONE could be described as having an effervescant action. Or simply as rapidly accelerating the natural process of decomposition.
Scott Warrington
