The Hitman writes again.
DUSTY
Hi all.
I just got this great article by John Braun sent to me by a google alert!
John has written a very good little consumer article that can really be very useful for your clients!
John does a lot of ad writing and consulting for folks in our industry. Certainly a guy you want to have on your team.
Area Rugs
There are a few basics you should know about rugs. Once you understand how to identify what makes a rug valuable, you’ll have a greater chance at purchasing a better rug.Rug fibers usually consist of wool in most mid to upper end rugs. High-end rugs may also have silk. Synthetic fibers such as acrylic, polyester, nylon, and olefin (polypropylene) can be found in more economical rugs. Cotton, sea grass, and sisal rugs are often moderate rugs. Your most stain resistant rugs will contain synthetic fibers, but won’t feel as soft and luxurious. All other natural fiber rugs are susceptible to staining if spots aren’t cleaned immediately.What do you look for in a rug? Quality of wool, type of dye, and knots. Simply because a rug is expensive, doesn’t mean it has good dyes or is constructed well. Make sure you know what it is and shop around first. Above all, be extra cautious about purchasing a rug outside the United States.The quality of a wool fiber depends largely on the type of dye used. Fine wool is vegetable dyed with fruits, roots, and plants. Cheaper wools and nylons can be dyed with synthetic dyes. A rug should always be tested for colorfastness by taking a damp white cloth and gently rubbing it into the fiber. If any color transfers on the cloth, the dyes are unstable. Also look closely at the fiber to check the integrity. Make sure it isn’t unraveling. Very fine wool fibers can often look as soft as silk even to an experienced rug professional.The construction of a rug is also a key factor. To determine if the rug is handmade, turn it upside down and look at the back. If you cannot see the pattern as clearly as on the face, the rug is not handmade. If the rug passes this first test, look at the fringe. The fringe should be an extension of the yarn inside the rug and should not look like it was sewed on separately. Many rugs that claim to be hand stitched are stitched by hand with a machine. You can expect to pay at least $500 for a small 3×4 hand made rug.BEWARE of rugs with cloth backings. These rugs have something to hide. The cloth is covering either flaws in a handmade rug or even worse, glue that is holding the backing together. Glued backings have a tendency to get torn when the rug is moved or cleaned.If you are looking for an alternative to a handmade rug, you might look at a Karastan. These wool rugs closely resemble hand made rugs, are cheaper in price, and rarely have the problems associated with cheaper wool rugs. If you aren’t ready to invest several thousand dollars in a rug, these will be your best bet.Ask the right questions. Educate yourself. Good luck in finding your perfect rug.John Braun is a writer for the carpet and rug cleaning industry. Visit his cleaning company’s home page at
http://www.CarpetCareTips.com
John has some great free stuff for the cleaning industry as well.
here is his Hitman advertizing website for you to take a look at!
http://www.hitmanadvertising.com/freelinks.htm
rhyde
Portland, Oregon
rhyde
I found this painful to read and if pointed at consumers very confusing
“The quality of a wool fiber depends largely on the type of dye used. Fine wool is vegetable dyed with fruits, roots, and plants.â€Â
seattle
This is the kind of "article" that gets printed in the odd filler spaces of women's magazines and then creates difficulties for everyone in the industry that has to re-educate customers that believe what they read.
Or, if marketing is his hobby, maybe he's decided that this will get confused people to call him for an explanation. Sort of a rug version of the "put lots of misspellings in your newsletter to make it seem homey" school.
Numero Uno
Ma
Caesar
This is where the kiss method comes into play...
Great info,but it is like reading one of my original ics bb posts...lol...
Pictures/Diagrams, that easily show pertinent items of info...
Coupled with more dynamic simple words...
Say it simple and to the point.
1...(Do not buy imported rugs outside USA...)
2...Why? ( Bad dyes,shrinkage,fade faster...)
Or Cheap rugs-cheap investment.
Quality Rugs -great investment.
They all want to know there rug is worth more in the long run,well hopefully if they keep it up...
This would be better made into a home show wall or scrap book.
With pictures of pros and cons and streamlined flow chart to build on each category if so interested.
This way they can browse and read /look at pixs at there leisure with no salesman.Cept pertinent brochures per situation to bring home...
What to look for in a rug,bad dyes and you,how to maintain,how to store,why call a real pro...etc...
My 2 cents,regards to all here...
