100% VLM ???
frank fratto
frank fratto
I just ordered that stuff yesterday and it's here already
Tank was from Amazon and the Hushtone came from a ebay Seller in Ohio
The Ebay Seller sent me the tracking number 30 minutes after I bought it
There are a lot of good deals on ebay
So many things you can do with a175 and few other pieces of equipment.
Like a small portable and water claw.
It is slower some times and some times it isn't ?
But you can clean just about anything with VLM!!!
I got a lot of experimenting to do with a 175-300 to see what works for me
To start I will use it to put down cl02 using a Fiber Pad or Bonnet Pro Multi Brush
Then put down prespray with WORX Sprayer and CRB with 14'' Brush Master Pro
Then extract with 175-300 and Microfiber
Then groom with 10'' CRB
I'm replacing the OP with the 175-300 for jobs using cl02
Get a 175 with a proper shower feed brush for applying clo2. You may want to add a little rotary shampoo for lubrication.
SteamwayPro
George
I have the 17'' Bonnet Pro Multi Brush and 14'' 15'' Drivers that have holes to shower feed using a Fiber Pad
Just got to be very careful near baseboards with oversized Driver
12'' Driver and 12'' Brush doesn't have the shower feed holes
I got a lot of practicing to do at my Apt Complex before I use this on a customers carpet
Gotta put down enough solution but not over wet carpet either
No customers around on Apartments so I can practice putting the right amount solution down
frank fratto
frank fratto
So true, Just enough liquid to move soil..
Condog
Tony
ConDog is not, I repeat, is not going to the dark side. Where you been Con? Y'all just skipped right over the two porty extractors. THAT makes him a dual method cleaner when the need arises. Not real sure you could put him in the VLM only category.
Hi Kenny,
Been busy with work and family.
Most my work lately is hard surface.
Occasionally upholstery, rugs, some carpet.
Just did a couple vct jobs, so I think we have to be versatile these days.
I like portables because they let you get a quality rinse on hard surfaces, which like I said is most of my work.
I use the Westpak Wand mostly.
I know a truckmount speeds jobs up, but at 63 years old just supplementing my retirement I don't want the debt or expense of maintenance and payments of a truckmount.
I respect people who make a living with them they provide great benefit, but I get by fine with my system.
The job I did this weekend had luxury vinyl, tile and grout, vct and commercial glue down. 175 and extraction are vital for commercial.
Condog
Tony
I used the Multi-Brush for the first time last week.
It gave amazing results, and I didn't even use a bonnet just a fiber pad. Ewwww, lol
I did grind off the spikes that hold but tear up the pads and glued on velcro to hold the pads.
I think I drilled in some holes for the cleaner to drip onto the pad
frank fratto
frank fratto
Frank another Red Pad on a Swirly
That machine looks NICE
Life is BETTER, when you're VLM !!!
View: https://youtu.be/fiaWNRLAIyQ
Here's the process i did this morning on a empty rental unit.
Pre-vacuumed with the Sanitary
Pre- sprayed 2 rooms at a time with battery pack sprayer. {6 small rooms total}
Brought in 2 small 13 inch 175.
Red pad under one---- microfiber pad under the other.
Start at the farthest point of my exit door, work my way out. 2 rooms at a time.
Give it a quick rake.
The mix!
Carpet Details {LOVE THAT STUFF!}
16 ounces of hydrogen peroxide per gallon.
A shot of ammonia.
A shot of citrus cleaner [pick your poison}
I have done this on hundreds of empty units this way!!!
LET THE HATERS HATE!!!!!! LOL LOL LOL
Hi Kenny,
You and I are in the same category except for the truckmount. Plus I'm a lot older. My kids don't like using the TM, so not sure how much longer I'll keep it. I don't want to hire someone to run just that, but it's handy when we need to clean a rectory.
Reactions: Condog
The mix!
A shot of ammonia.
To each their own🤷🏼‍♂️
Reactions: frank fratto
Condog
Tony
Fridays/Saturday job
Luxury vinyl, tile and grout, vct and cgd.
For clarity on the vct I used a square scrub and spp pad to do a scrub and recoat, so the round marks that look like circles are old.
I did the carpet with the Bonnet Pro Multi-Brush. It was fast and removed all dark travel paths tracked in from the asphalt parking lot. In Phoenix it's extremely hot for half the year and oils get tracked onto carpet. In case anyone cares I used Encapuclean and peroxide on the carpet.
I like the heat of the Ninja during the extraction, it helps in rinsing and removing the slurry off of hard surfaces so it doesn't dry to the floor.
One weekend I did a strip and applied 4 coats of finish on my first vct job (at another medical practice) and the employee who was supposed to be there took off for a couple hours.
Somebody came in and was in the file room going through their records when the employee came back.
The employee didn't lock up and had the audacity to ask me why I let them in, I told him I didn't let anyone in and I didn't see anyone come in because I wasn't in the area in question.
I like that a portable doesn't require open doors, letting me work without concerns like strangers having access to the building or my trailer.
Condog
Tony
The mix!
A shot of ammonia.
I prefer to apply the cleaner from the tank on the 175.
When I use the portable I pre-spray, but not with vlm.
SteamwayPro
George
The mix!
A shot of ammonia.
I never added anything to Carpet Details because it says on the website not to add anything
frank fratto
frank fratto
View attachment 133496 View attachment 133497 View attachment 133498 View attachment 133499
Tony ,I never used the square scrubber.
Do you like it?
Encap store usually has good deals on the Swirly. Ordering it with the big wheels, tank and sprayer is cheaper than going through Hawk I believe.
SteamwayPro
George
Just like riding a bike.
One job today for long time customer with old nylon. I go to this house 2 times a year
I'm using Carpet Details with 5 oz of peroxide
You say no heat
A few years ago when it was my main cleaner I thought I got better results using Carpet Details with hot water
It's cold 25 degrees and I take my own soft water. So that water is cold when I get to customers house
I put a bucket heater in jug when I get there so water is at least warm 80-100 degrees when I start cleaning
Is that ok ???
frank fratto
frank fratto
George,
look at the new video Pauly C, put out.
His channel "PNWFLOOR GUYS"
Starts 2:50 into it.
I think we talked about this in the past?
frank fratto
frank fratto
You say no heat
Is that ok ???
Yes, warm is OK , not hot.
Here in Florida water is always 80' or Hotter LOL!----[ I haven't took a cold shower in five years LOL! ]
Those Steamers are pre-spraying with 200+ degrees!
Not good if you are using Hydrogen Peroxide.
WE can use it all day long!!!
Reactions: SteamwayPro
frank fratto
frank fratto
I find Carpet Details, works best if you give it 10 to 15 minutes of dwell time.
SteamwayPro
George
George,
Guess who got Pauly C using the WORX Sprayer. ME about 5 years ago
He was asking about sprayers and I told him to buy a refurbished WORX off ebay
He did and he loves it
I also recommended changing the wand but he still uses that short WORX extension
SteamwayPro
George
Frank after I finished I went back and checked on the 3 Bedrooms
The carpet was nice and SOFT and DRY
I did 3 Bedrooms and a Family Room
Used Carpet Details at 5 oz and Detonator at 5 oz
LESS water MORE agitation !!!
frank fratto
frank fratto
WE should all Help are competitors.
it will help our industry.
Pauly C was smart to listen to your advice!
We all can learn from each other!
I agree with you, i like the long handle!
frank fratto
frank fratto
I was sweating Bullets!!! lol
It's always good to have another back up system!!!
I'm glad it worked out!!!
That looked to be a very NICE job well done, in the picture!!!!
SteamwayPro
George
I got one Apartment to do at my Apt Complex tomorrow
I'm going to have some fun with the Hawk 175-300
Wahoo !!!
Latest Auctions
