100% VLM ???
Tm- guys bring up residue from the back of the carpet oh wait, I mean re-soil from the backing of the carpet!!!
From those #9 blowers"& " 500 psi"" My bad "Sometimes I get mixed up??? Sorry
Do you even clean carpet hahaha
A sub surface tool can pull moisture out of the pad, I doubt we're pulling all the dust that gathers under the carpet with a primary secondary backing and latex glue.
But your probably sharing from personal experience, which makes me wonder if you know anything about chemistry
SteamwayPro
George
The ANGRY Steamer is PISSED OFF again
Samlam has - VLM Derangement Syndrome
Irrational reactions to people that use the VLM Method
Samlam PLEASE call this number for HELP
1-800 Anger Management
Reactions: frank fratto
frank fratto
frank fratto
A sub surface tool can pull moisture out if pad, I doubt we're pulling all the dust that gathers under the carpet with a primary secondary backing and latex glue.
But your probably sharing from personal experience, with makes me wonder if you know anything about chemistry
What's the number one complaint about a TM job??? Too WETTTTT too Longggggg.....
Second complaint a very closed second RE-SOILED.....
Doesn't take a chemist to figure that out๐Ÿคญ
Reactions: SteamwayPro
I use fans and last step rinse with a speed drying agent and a 4.8 blower.
Drying isnt a issue I have a problem with.
You two idiots are name calling and bashing steam cleaning.
I couldnt careless how you clean.
You haven't discovered the holy grail, you're probably broke dicks because maintenance broke you.
Hahahaha
Peroxide vlm you don't know!
Know what?
How dumb
frank fratto
frank fratto
Hahahaha
Know what?
How dumb
Sam
Nice picture GOOD job!!!โœŒ๏ธ
4.8 not too big but she said it will get the job done๐Ÿคทโ€โ™€๏ธ
Remember, who started name-calling? I think it started years ago???
Hot water and hydrogen peroxide don't go there that's a NO-NO๐Ÿคฏ
SteamwayPro
George
Going back to the early days ( 2012 -2019 ) when I first started experimenting with VLM VacAway had a VLM Forum and I would be the TM guy asking all the questions
Joel Hoppe answered all my questions
I used to tell him I should be sending you a check for educating me
THANK YOU Joel
It's now 2026 and I have developed my way of using the VLM Method
Completely different from the way Joel uses VLM
LESS water MORE agitation !!!
THANK YOU Joel
No tank?
Can you explain your process on residential please
SteamwayPro
George
No tank?
No tank for residential
Because I believe you need to CRB residential carpet
1 - Vacuum
2 - Spray down Detergent
3 - Scrub with CRB
4 - Extract with OP
5 - Groom
But I have considered putting a tank on my CRB
Having a tank with sprayer on my CRB would eliminate one step and make the process faster
I wouldn't be able to use it on every job but for Houses/Apartments with no furniture it would work
View: https://youtu.be/XJtMXY9OSMU
1 - Vacuum
3 - Scrub with CRB
4 - Extract with OP
5 - Groom
Do you keep a small spray bottle on hand for areas or spots that need more juice?
SteamwayPro
George
YES
It's called VacAway Spot-n-Boost or Spot-n-Boost Green
I mostly use the Green version because it has less odor
Just mist it on spots or traffic lanes agitate with CRB or drill brush
It works !!!
frank fratto
frank fratto
1 - Vacuum
3 - Scrub with CRB
4 - Extract with OP
5 - Groom
Funny i took my tank off my CRB
and all my 175.
I guess I'm forced to use dwell time!!! โœŒ๏ธ
SteamwayPro
George
and all my 175.
I haven't bought it. I have just considered buying it
It wouldn't work on every situation
Most of the carpets I do at my Apt Complex are spotless. It would work on them
For trashed carpet I would prespray with Worx first and then just add some from CRB on areas/spots that needed more
frank fratto
frank fratto
I'm sure if you buy it you'll find many situations to use it๐Ÿ™‚
Heck, I could even find a situation or two to use a TM ๐Ÿ˜‚ most likely not๐Ÿ˜‚
frank fratto
frank fratto
I think I'm going to order one of these. I had one way back, but I could never get it to prime. I think it was defective because I tefloned every thread and connection.
Same problem, I keep a ketchup mustard squirt bottle in my van full of water with the pointy cap.
Prime it out in the driveway.
Reactions: Living The Dream
frank fratto
frank fratto
Frank let me know if I missed anything
Advantages for using the VLM Method
1 - NO petroleum needed
2 - NO TM blasting away disturbing the neighbors
3 - NO TM emissions polluting the environment
4 - NO doors open or security issues
5 - NO doors open allowing cold air in or warm air out Winter or cold air out and warm air in Summer
6 - NO doors open allowing insects in ( Florida Snakes Alligators Lizards )
7 - NO doors open allowing cats-dogs to get out
8 - NO close parking issues
9 - NO dumping dirty water issues
10 - NO van doors open allowing rain snow to pour in
11 - NO van doors open inviting thieves
12 - NO long Dry Times
13 - NO vacuum solution hoses covered with mud snow rain when working in bad weather conditions
14 - NO long set ups dragging carrying vacuum solution hoses from van to house 300 ft - 400 ft of hose
15 - NO maintenance issues
16 - NO ridiculous priced TM
17 - NO ridiculous priced TM repairs
18 - NO ridiculous priced TM replacement parts
19 - NO worries of TM water pump or solution hose freezing on a job
20 - NO heaters needed at night to prevent TM freezing
21 - NO worries of TM breakdown on job or difficult repairs on job
22 - NO worries about wicking
23 - NO worries of dull dingy looking carpet after drying
24 - NO large lease or loan payments every month for TM
25 - NO low profits because of high business cost
Disadvantages for using the VLM Method
1 - It's slower on Medium and Heavily Soiled Carpet
I love VLM !!!
Hey George,
how much ๐Ÿ’ฒmoney have you been spending onโ›ฝ GAS sitting in the driveway
when you're cleaning carpets๐Ÿค”???
SteamwayPro
George
Hey George,
ZERO and I had a busy week 6 days of work
Did a TRASHED apartment yesterday should have taken pics but I just wanted to get done
My Hoover Hushtone vacuum got clogged should have never used it on that mess
I usually use Kirby on TRASHED Apartments but for some reason I grabbed Hushtone
I got some stiffer brushes ( brown) for my 14'' CRB to be used on TRASHED polyester carpet in Apartments WOW did they do a good job
And of course I used VacAway Double Trouble the BEST encap for Polyester carpet
I love VLM !!!
frank fratto
frank fratto
I love VLM !!!
I bet gas stay up until the middle of September?
1 to 3 gallons a hour sitting in the driveway?
Kirby, they are a Tank, a workhorse!!!๐ŸŽ King of vacuums!!!
Don't think I'd ever buy a Hushtone unless I got a good deal on a used one? They're just too pretty๐Ÿ˜‚
George, you talked me into it? I'm gonna order me some Double Trouble!
  • Love
SteamwayPro
George
Oh no I wasn't trying to talk you into it
But it gives me the WOW
Nothing I have used cleans polyester carpet better than Double Trouble
I usually use it at 2 oz
3 oz TRASHED
Hopefully you're not disappointed after hearing all the hype coming from me
frank fratto
frank fratto
3 oz TRASHED
Hopefully your not disappointed after hearing all the hype coming from me
I'll keep you posted โœŒ๏ธ
SteamwayPro
George
Easy job today
Carpet Details at 5 oz
Long time customer at least 15 years
Family Room Living Room Dining Room Steps Hall Master Bedroom
There were a few small pet stains from her Boston Terrier that I used VacAway Oxi-Moxie on. It's a crystallizing Hydrogen Peroxide spotter that WORKS
VacAway spotters are outstanding. I used them even when I was HWE
frank fratto
frank fratto
Easy job today
Hydrogen peroxide is Magical!!!
TM guys haven't realize the power of it!
Got to be very careful with it[ Heat ๐Ÿ˜ฎ]
They don't use enough of it because they can't๐Ÿค”โœŒ๏ธ
PS. Nice Job!!!
Rick J
rick Jones
OK , not a knock, just maybe being realistic, there are limitations.
I love my VLM tools. Worx ,, original CCS OP Stepson
and ,
drink the Kool Aid time to time.
many years ago,, Vacaway claiming they are the best , newest at oily terribly soiled olefin!!! Heck yeah!! I'll try anything.
I forget which version it was back then.
Had a real test. Vacant home. some of the thickest , densest olefin you will EVER see. inch deep, could barely push my finger between the face fibers to get to the backing. White, TERRIBLY soiled. (old pics, with old phone don't do it any justice)
Got some of the aforementioned juice. And being realistic , realized the situation was not one for 100% VLM. I actually used the juice as a HWE cleaning agent first. Yeah foam, foam ,,, foam, I was anticipating that. and dealt with it. But , wanted to see if the touted magic juice of the day was IT! So performed the PITA foam filled HWE .
Quite a bit of drying strokes, BUT, I knew , plenty of that magic juice was down in there. just waiting to drag the oily, soils up into my absorbant bonnets spinning under my OP, leaving it like new.
NOPE!!!! traffic lanes still dingy. and NOOOOO, no blend mend! LOL! ๐Ÿ˜œ๐Ÿ˜œ
Again, meant for me as an experiment. Spent probably 5-10 X the time that area should have taken.
frank fratto
frank fratto
and ,
I've done many of those?
I'll take a 175 any old day and whip that greasy dirty grime right out of the carpet!
With more than a half a dozen different chemical mixes.
No disrespect ๐Ÿ™‚ It's just grease dirt and who knows what else?
Should come out really easy!
Just another Tuesday!โœŒ๏ธ
