- Oct 7, 2006
- Name
- Jimmy L
scottw said:Glycolic acid gets me vote as well for the best chocie.
It should be noted that none of the products is simply acid. Some acid rinse products may add color, fragrance (not all acids smell great), surfactants for detergency, corrosion inhibitors, a small amount of mildecide (so nothing grows in the open containers) and so forth. Some encapsulants may also be added to help reduce wicking.
There is some science plus lots of trial and error to developing a great rinse product. It is not just pouring some acid in your 5 gallon stock jug.
Daddy said:I never meant my question to imply just pouring some acid into my jug but what is the best acid in the formulation.
Greenie said:Interesting notes on Quats in the rinse or softening cycle. So maybe Les wasn't crazy by adding DD-12 to the TM rinse jug.
Daddy said:I'd buy some if it was around the $20 gal. price range.
Jose Smith said:I have always preferred Chemspec's All Fiber Textile Rinse because of the Glycolic Acid (hydroxy acetic acid). It is also in Prochem's All Fiber Rinse, but for some odd reason they reduced the amount used a few years back. Jose Smith
HARPER said:Greenie said:Interesting notes on Quats in the rinse or softening cycle. So maybe Les wasn't crazy by adding DD-12 to the TM rinse jug.
Exactly.....
Art Kelley said:HARPER said:Greenie said:Interesting notes on Quats in the rinse or softening cycle. So maybe Les wasn't crazy by adding DD-12 to the TM rinse jug.
Exactly.....
Of course we all know that fabric softeners and quaternary disinfectants will reduce the stain resistance and void the manufacturers warranty don't we?
Shawn Forsythe said:In no particular order, Chemspec's All Fiber Rinse, Interlink-BP Select Professional Neutralizing Rinse, Hydramaster's Clear Water Rinse are just a few that use Glycolic acid.
Shawn Forsythe said:I tend towards 2-hydroxyacetic acid (glycolic) or sulfamic acid.
The glycolic acid is actually going to have some cleaning properties that ordinarily don't exist for the acidic component of a rinse agent.
p.s. 2-hydroxyacetic acid (glycolic acid) should not be confused with Acetic Acid (ethanoic acid), which has quite different properties.
ACE said:It is my understanding that glycolic acid is just a highly concentrated Acetic Acid. Water down Glycolic and you have Acetic.
