Aramsco acquires Jon-Don
CHANGE is not easy. I get it especially for you older guys
You must flood carpets with gallons of water to clean it ... WRONG
I will check back on the GROUP THINK in 2030
And I will continue to promote the VLM/SETT Method as the PREMIUM carpet cleaning Method
When done correctly
The FUTURE of carpet cleaning is VLM !!!
Why is the name of your company steamway pro??? Seems a little like bait n switch why not rotary clean or low moisture soulitions carpet cleaning or dryer cleaning soulitions anything but the word steam . As a hwe cleaner that Seems a bit deceiving and misleading to me
Seems suspicious doesn’t it?
I think it’s just there to be controversial. What better way to get the post count up?
Reactions: Dr. Kleen
SteamwayPro
George
0ne MILLION Views is that right ???
How many times has one topic hit 0ne MILLION views
We all know the One MILLION views is not about Aramsco acquires Jon Don
I would say it's about the future of Carpet Cleaning and the VLM/SETT Method
But I'm sure the GROUP THINK will disagree !!!
they live
It was me and my adhd.
SteamwayPro
George
Two MILLION
How many times has that happened
The VLM/SETT Method is taking over the Carpet Cleaning World
But the GROUP THINK is still in denial
Two MILLION
I do both methods. Had a job recently that I would have dreaded using encap on. Realtor job in a condo full of dried feces and urine. I could have encapped it but means vacuuming and contaminating my vacuum cleaner, prespraying an enzyme to start, CRB it in, use 2 types of pads to scrub and extract with an oxy-encap. Probably would have taken 3-4 hours. Realtor isn't prepared to pay that much. Went in with my portable, presprayed with a high pH products that contains enzymes, oxidizer and solvents, let dwell a bit then rinsed with another high pH rinse in the tank. 1.5 hours and the carpets look improved enough to begin showing the listing. There is a place for VLM but it's not better or worse than her, just an alternative system.
Reactions: jessi
Two MILLION
Spoken like a person that eighter can't afford to buy a real cleaning machine or is too cheap to buy one been hearin the same song since the 70's vlm didn't run me outa business then eighter hot water extraction has gotten way way better since the early days but vlm well, same process less toxic same propaganda buy a cheap brush machine make 250k per year on a 1k investment yada yada yada. expand! Buy a cheap ass rotobrush duct cleaning system and run them "stupid ass negative air guys with their 60-100k worth equipment outa business also while you're at it
SteamwayPro
George
But it's not the 70's anymore ... hahaha !!!
Are you guys still wearing Bell Bottom Pants and driving Volkswagen Beetles ???
EVERYTHING changes including Carpet Cleaning
LESS water MORE agitation !!!
  • Eyeroll
All of that is true, but it’s not true for everything. How many eye rolling, laughing emojis do you need before you get it. You’re not even changing anyone’s minds on sett or whatever you want to call it. It is what it is. I
use every method, which is the easiest EXCEPT dry compound if I can help it.
Most humans don't realize when they lie to themselves, let alone to others..
If a higher authority were to create a list of Must Have tools/ methods to own and master in order to be able to legally call yourself a professional floor cleaner, the following would have to be on that list
A truckmount, unless you only work in high rises
A OP
A 175
A CRB
A clean carpet wand
and a dirty carpet wand..
A multi-surface wand
A spinner
A nice fabric hand tool
And a filthy fabric hand tool
Finally, a Hydroforce, and the wits about you to properly use and maintain it..
If only been Jon-Don sale staff knew this verbatim ,they may still be in business
View attachment 131688View attachment 131689
Its certainly not the 70s but you seem to be stuck in it . Host was the vlm latest greatest process back then, they were gunna run all us rug suckers outa business what happened to them?? O yes chem dry came along in the mid 80s and host went away . But what happened to chemdry?? Somewhere in this century They quietly jumped ship and switched there process to hwe of course keeping the attitude "were superior because were carbonated " (but we now clean hwe) meanwhile you seem to be stuck in last century. With last centuries technology. All i have to do to compete with a company like yours is carry 2 pictures in to show potential customers during an estimate and ask um which machine would you want to clean your carpets?? The little brush thingy or a V8 powered monster? Guess which the advantage and the above advantage potential customer will choose?? You don't have to answer that, we here all know the answer already, sowith that said, in short whether you like it or not, agree or disagree...."the solution to carpet pollution is still dilution "
SteamwayPro
George
BEAUTIFUL Set Up if it was still the 90's
You can still do it that way, but unnecessary
That's called OVER KILL !!!
You made the sellers of that very happy ... CONGRATULATIONS !!!
It's 2025 and you don't need to POWER WASH carpet with 25 Thousand to 50 Thousand Dollar Machines to get them clean anymore
The CEMISTRY of carpet cleaning has improved dramatically over the last 10 years
So lets not over complicate Carpet Cleaning. It's a very simple process
I would agree that Dwain is over cleaning most of his repeats with the RX-20/ Drag wand approach.
He could get great results, better dry times and double or triple his current production rates with a vacuum, apply the juice, crb as needed, and rinse with a 12"/ Hole Glided two jet wand
His customers, profit margins, lower back, joints and the carpet all would be better off
Alot of cleaners have shown me how to do it quicker. There has yet to be one to show me how to do it better. Im always willing to watch and compare and i have the perfect dirty carpet for a fair comparison.
You definitely don’t want to start CRBing carpet. There’s some things you need to ignore. Keep doing what works for you.
It's like saying I'm going to pick my ammunition type to go squirrel hunting based on what it takes to take down an elephant...
I'll pass on watching
The unfortunate opportunity takers during all of this are not helping promote trust in their brands. Imo...
I agree with that. I really don't care about why something collapsed, unless it's by design. Now that intrigues me. The Cox Convention Center
here in OKC will collapse on purpose to build a new Thunder arena. I will be interested in that.
I watched the first one. I appreciate the opportunity to learn from it. Any serious supplier should watch it for clues to watch for within their supply chain. Life happens, and despite of virtue signaling opportunities, there’s no benefit from ignoring it.
