- Oct 7, 2006
Not a good visual.
Kevin P said:Ya, but your summers suck![]()
When the wind is blowing 25mph and you have van doors opened up it's going to get colder much faster in side that van then if you had a 1 mph wind.Brian H said:Can someone please explain to me what the wind chill factor has to do with freezing solution lines? From my understanding, the wind chill factor is the way your skin feels with the temperature and wind speed factored together. It does not have any effect on freezing solution lines. 35 degrees outside with a wind speed of 25 mph will yield a wind chill factor below freezing but will not freeze the water.
We have cleaned in -20 degrees many times. My rule of thumb is solution line last and you have maybe 60 seconds at most from the time it hits the ground until you have to have teh trigger on the wand pressed.
Jim Martin said:[quote="Kevin P":3dpglqv6][quote="Jim Martin":3dpglqv6]anything below 60 and I am just not worth a shit.........we have been around mid 70's for the last few week...
this week we have a few 62 days....couple more degrees and I will have to reschedule.....
[/quote:3dpglqv6]
