- Nov 7, 2006
- Name
- Shane Tiegs
The Dwyer 203B has an adjustable valve in the body and a metering screw on the side. With this one you need a flow meter to monitor your flow setting.Yo
You can buy a Dwyer with the flow meter (all one unit) so you don’t starve The pump as you limit the solution feed. It’s on “that side of the T fitting”. If that makes sense.
