- Oct 22, 2012
- Name
- Ron Marriott
As I sit here talking on mb, I just booked a job for the week of July 16th. 3 small apt buildings. $500-650 each. Each one will take aprox 3 hours or less. This is my bread and butter.
Plus your driving gas.So is it fare to say about $20 a day in gas?
That would be the same with either machine. If they decide to install a generator... it's the same.Plus your driving gas.
Depends on the size of the motor and gas tank.Generator can run about 8 to 10 hours on gas. TM's are around the same?
The main difference is in the power, no amount of electric vacuum motors is going to give you the same punch as even a 36 blower will give you. With the etm, you will limited to 150 ft and under. When you add all the components together, the etm isn't too far off the price of a good TM. There are entry levels going for $12,000 aprox that will out perform the etm. Not saying you can't do it and do good work with it, just saying for a few dollars more......The time to set up with the ETM is the exact same as using a Gas powered TM if one has a generator. Literally flip the switch, hook up to clients water, take in high pressure hose, vac and go. I don't see where one is taking extra time to hook up. Again, if you are using a generator.
My Honda machine will run 7.5 hours on a 9 gallon tank. I usually don't have many jobs that go past 5-6 hours.Valid points. clean works how many hours does a TM run on gas VS 8 to 10 hrs on a generator? Some Generators for 10-12hrs depending on the wattage
If you're using a generator, It's no longer electric powered. You're back to a gas powered system...with a hitch.The time to set up with the ETM is the exact same as using a Gas powered TM if one has a generator. Literally flip the switch, hook up to clients water, take in high pressure hose, vac and go. I don't see where one is taking extra time to hook up. Again, if you are using a generator.
If they are the latest machines, I would lean towards the hydramaster. The new 318 has a clutch and can be used for water extraction only if you do any flood work. Other than that both will perform similarly. If you have a good relationship with a shop owner, maybe that's the way to go. Either one will give you better performance than an etm.So Cleanworks, sooper hero and Charlie. I have recently been offered a HydraMaster 318 for 13k and a Prochem Blazer for 13,500. The HydraMaster will cost me less when considering the shops install fees and what not. Hose run? Heat? Longevity? Which provides best in your opinion? I’m leaning toward HydraMaster only because I know owner of shop and a little less to install.
Neither one is going to give you huge heat but should give you enough to clean residential carpet well. I think both will be fairly similar. If I am not mistaken, the Blazer is going to or already is discontinued. You want to take a look at what comes with each unit. Look for a larger waste tank, premium wand, extra hoses, additional tools etc. I really don't think you can go wrong with either one. Look at who is going to service it for you. Either machine will be a good choice for a first tm. Both should be reliable with regular maintenance.Both are the latest and brand new units. Is the heat sustainability the same for both units?
I love Hydramaster. But...the 318, I think is less power than the Ss rage.So Cleanworks, sooper hero and Charlie. I have recently been offered a HydraMaster 318 for 13k and a Prochem Blazer for 13,500. The HydraMaster will cost me less when considering the shops install fees and what not. Hose run? Heat? Longevity? Which provides best in your opinion? I’m leaning toward HydraMaster only because I know owner of shop and a little less to install.
