Equipment upgrade- Is this a good plan?
Will D
Will Doublestein
Hello everyone, this is my first post (sorry it’s long!), and I’m excited to hear your advice. I’m 36 years old and have cleaned carpet both residentially and commercially for the last ten years or so, though only ever as a side-hustle. Everything I know I learned from my Dad, who also cleaned carpet on the side (30 years), and while I suspect many of you won’t agree with the recycling CFR portable extractors we’ve always used, we’ve had very happy customers all along the way. I’ve decided to stop taking residential jobs and now have just three commercial customers, which is all I can handle, and I hope to keep those customers for a very long time.
With that background out of the way, I’m ready to upgrade my very old equipment, and before I pull the trigger I’d like to run my plan by pros that understand what I’m trying to accomplish (thanks in advance!). I don’t want to invest in a truck mount, so a great portable extractor is what I’m looking for, and while I might upgrade tools down the road I plan to only use a wand for now. I’ve always loved the recycling machines because they keep me from emptying and refilling so often. Still, I’m ready to move on from those because I understand the contradiction of cleaning with recycled (dirty) water.
Having said that, my plan is to buy a Rotovac Ranger. It’s a CFX-ZX dual vac with auto pump-out (220-240” of water lift, not sure the cfm), attached to a 27 gallon Ranger base tank. The base tank has an adjustable 1200psi max pump with auto fill, so essentially, I could connect it to hot water from a faucet and clean all day with auto pump out to a toilet or drain, never needing to stop to empty and refill. The CFX-ZX claims to be able to run 200’ of hose, though I would start with maybe 50-75’ (my current hoses are maybe 15-20’).
Here’s what I need to know:
1) Do you see any flags with the Rotovac Ranger 1200psi? One day I might add the Rotovac 360i rotary tool, which could be run by the CFX-ZX even without the Ranger base tank/pump. The CFX-ZX weighs less than 50 pounds- would be a breeze to transport between jobs. The Ranger base would ensure I could get to every part of the giant buildings I’m cleaning, even where I couldn’t connect to a faucet.
2) What diameter vacuum hose should I use? I’m currently running 1.5”, should I switch to 2”?
3) What PSI should I run the pump at? I have a four jet wand, and I can’t remember what size jets I have on it. I’ve found lots of varying opinions on this, but I’d be interested to know your thoughts. Please throw out the jet sizes you’d recommend too so I can make sure that what I have is good.
4) I’m looking at upgrading to a Hydro-Force injection sprayer for my pre and post sprays. Would you recommend anything different?
5) What am I missing? Is there another portable system that I should consider instead? I know… a truck mount would be awesome, but it’s not in the cards any time soon…
Thanks for your help everyone! Please forgive my ignorance- Dad is the only one I’ve ever learned from, but he’s been out of the game for a while. I really need to find other professionals who could guide me a bit, and I’d very much appreciate your thoughts.
-Will
Reactions: Condog
I have one (which Ill sell you for dirt cheap) and it's too big, and needs too many cords with the base being used. The top portional has limited potential but would probably be a wise things to have on board if you dont want a truckmount.
NO.
1/2" with Portables.
Ditch the 4 jet, Portable dont have the flow to use them effectively. 1 or two jets only. And use a Hole Glide whenever possible.
A hydroforce isn't going to be time and energy conducive with a portable.
Are you all in or is this a part time beer money hobby?
IMO, get a PEX 500 portable, a 10" CRB, a OP machine, an electric sprayer and attend Mikey's Fest in April (www.mikeysfest.com) where I'll put you in contact with the very best in this industry to learn from our mistakes, and within those 3 magical days the rest of your cleaning career will be clearly defined and sorted out, assuming you can take direction well, which most most carpet cleaner can not.
Your Dad didnt do you any favors, sadly enough, but you found the Truth here, I hope you can hear it.
Reactions: Condog
I didn’t actually read Mikeys post but I bet I can sum it up by saying he tried to sell you a wand, disked the Rotovac portable and mentioned an OP machine you need.
Reactions: Bryce C
Will D
Will Doublestein
Thanks so much for all the great info Mikey! I wouldn’t say I’m all in, but it’s not a hobby either. My primary profession is teaching, but I’ve got four kids… and carpet cleaning helps me make ends meet. I have a third job ans well, and balancing all those things has been a hard challenge to navigate. Still, I’m super grateful to have carpet cleaning- it’s an incredible way of supplementing my income. I don’t think my Dad did it perfectly, but he has an incredible work ethic, and his customers picked him over the other guys for decades. His biggest hurdle was efficiency, and I’m sure there are ways I could improve. Looking forward to learning more from all you guys!
I’ve got some follow up questions-
1) I think I’m ok with a bigger machine if it means I don’t have to dump and fill all the time. Are there three cords on it? That is a lot… but manageable in the types of buildings I’m working. I’ll have to think about that… Have you had any problems with the suction or the pump? Let me know more about your machine and how much you’d like for it if you’d really consider letting it go.
2) I thought bigger diameter hoses meant more cfm- but I’m new to that conversation. The CFX-ZX claims to handle 200’ of 2” hose, but I don’t know… My current machine are set up for 1.5”. Can you tell me why 1/2”? Just interested.
3) I’ll definitely look into that Hole Glide- thank you! Does your opinion on jets change with the adjustable pump at all? I’ve had great success with that wand, and I also have multiple 3 jet wands that have done great too. Help me understand if you can.
I’ll definitely look into your other recommendations too Mikey- thanks so much!
NO.
Why isn't getting a truckmount an option?
Can you tell us the average length on these commercial jobs you have that measure from where you park your van to the farthest from the entrance? If it's over 250ft, I understand if you don't want to invest in a $45k machine for just 3 contracts.
BUT...
Will D
Will Doublestein
BUT...
Will D
Will Doublestein
Yeah, it’s just that I’m only cleaning about 5-7 hours a week. Definitely would consider it if I were cleaning full time.
Used once and been sitting for 12 years. If you can figure out how to get it to you without any headaches, you can have it.
This industry loves to (over) exaggerate performance claims.
Bigger hose does not create more CFM, bigger vacuum motors do.
I'll let @Cleanworks Ron and @Willy P, our resident Porty experts explain it to you.
View: https://www.youtube.com/watch?v=j7YH2ZRFmiQ&t=2s
Hole glide speed up the (slow) air of a (portable) system.
Faster air travels deeper into the carpet pile.
What happens when you purse your lips tighter and tighter when you whistle?
Will D
Will Doublestein
This is all super helpful- thanks Mikey- already learning a ton! Let me reframe my question just a bit. Are there any portables that have an auto-solution and auto-pump out, that also have good suction and a strong pump? The ability to clean without dumping and filling water all the time is pretty high on my wish list. Does such a thing exist? I just saw that Rotovac’s Monsoon has both auto pump/fill on their 500psi portable, with two 15 amp cords, which is as close as I’ve found. @Cleanworks and @Willy P, what do you think? Thanks for your willingness to help- I really appreciate it!
And Mikey, I live in Indianapolis, are you driving or flying in for Mikey’s Fest? I’m brand new here and have no idea where you’re located. If you’re driving in and can bring that machine with you I’d be happy to buy it. Might be a way to tide me over, and at least get me out of my CFRs recycling units...
Just a couple of things. For commercial, you might think about getting into encap instead of hwe. You can do great work with a Trinity Phoenix with the right chemistry and pads. If you are stuck on hwe, the Rotovac monsoon or cfx machines produce great vacuum giving you the opportunity to use 1.5 inch hose or 2 inch hose on longer runs. I prefer to move the machine and use shorter hose. As Mikey says, a 2 jet wand will work better, a 4 flow will be all you need. Contrary to what Mikey says, an in-line sprayer like a Hydra-force will speed up your prespraying. I use a Hydra -Force both with the truck mount and portable. I usually use a 35 hose if 1.5 inches on most of my portable jobs. If I need to go longer, I switch to 2 inch with a 1.5 inch whip on the end. Usually 10 feet. I have been switching most of my commercial work to encap. If you go to the Mikey's Fest, spend some time learning how to use the Trinity Phoenix.
I live in Northern Nevada
We will have a few local cleaners bringing support equipment and manpower.
As well as many manufactures sending supplies and equipment.
Amazing that your there, right?
You're about to get a 5 to 10 year head start to your business, congratulations!
You'll be meeting the best of people there, both in business success and in being the best of human beings.
Will D
Will Doublestein
Thanks so much for this- SUPER helpful! Very grateful for the details, and yes, I’d totally be open to learning more about encap and the Phoenix at Mikey’s Fest.
There are companies that will come pick it up at my house, put it on a pallet and deliver it to you...
Reactions: Will D
As Mikey said, I would recommend the PEX 500 over thee Ranger. As have been said before, it a Swiss Army Knife of portys. The release valve to change from tool to tool is awesome. Two cords of course but there is a circuit breaker light indicator. It has high, low heat, and you can move it effortlessly. It loads fairly easy, and you can even lay it down to transport. It has a side discharge hose and a hose hanger. For a porty, it’s awesome. Put that with an orbital or a Cimex, and bam for commercial. I use my TMs vey little.
Reactions: Will D and Condog
I do have a Cobra 1200 psi with auto fill and dump. Such a pita to use. Garden hoses going all directions and cords meshed in between will drive you nuts. It’s a box type machine, and even though it has a built in hose reel, it’s a pain to maneuver. No porty compares to the PEX.
Condog
Tony
I have the CFX/Ranger.
I worked with a friend who got rid of his to get a Ninja, because he didn't like all the hoses running off the CFX/Ranger.
I prefer the ease of the Ninja over the CFX/Ranger.
He has since purchased a Monsoon, and he loves it.
It's basically the CFX/Ranger that can be run like a Ninja but has the ability of setting up like the CFX/Ranger.
You can choose which set up works best at each location.
I haven't run the Monsoon yet, but hope to have one asap.
Good luck, I'm part time too.
Condog
Tony
NO.
I don't know about the PEX, but you've never steered me wrong Mike. In fact you've given lots of good advice over the years.
No matter how you look at it a portable is a pain. Like many here I started out with a portable. A US Products Solus 310. I ran 25' of 1.5" hose with a 2 jet Evolution wand.
In the beginning I was always thinking I needed more vac and psi. But I learned that with proper wanding my dry times were just fine. As far as psi I found that 310 was more than enough with proper chemistry and agitation.
A 175 does wonders for portable users. I would use it to agitate my prespray and post bonnet after extracting. It completely changed my game and results.
I would also recommend that instead of getting an inline sprayer, you get a battery sprayer like a Multi sprayer or a SOS Gentoo. I have found them to be much quicker than a inline, especially if you have a limited to hose run. An inline also uses up your freshwater supply. Adding water and dumping water really cuts into production. I know you wanna run auto dump and fill, but it's not always available.
My recommendation would be to run whatever portable you can get for the cheapest and then move on to a truckmount. There's some really great deals out there.
I know a van can be an added expense, but depending on what your location is a trailer is a great way to get a truckmount without the added expense of a van and insurance. You can use your personal rig to tow it and also use your vehicle as a tax deduction. You can store all your equipment in there as well. It's like having another garage. If you live in a huge city where parking sucks than a van is a better option.
In carpet cleaning everything boils down to efficiency. If it isn't going to make you more efficient then you don't need it.
Reactions: BIG WOOD and Will D
My ( very ) early thoughts for those thinking of joining us ..
Almost every day I see somebody ask about getting into this industry, and all what is needed.
I'm going to keep this answer stored on my phone....
If you can afford to do it correctly, you'll go about it in an opposite direction than 99% of us did..
Get educated
Get connected
Get equipped
Get customers
Almost guaranteed success in that order if you have all of these natural born inherent qualities:
Great soft skills and pleasant to be around.
Handyman/tool skills.
Driven and ambitious.
A certain level of fitness.
Naturally curious.
Outgoing and braver than average.
A level of morality and honesty that goes far beyond being caught by the IRS or the maid.
Community/social involvement.
Adaptable to change, now more than ever.
You'll also need at least 100k to get fully and properly equipped.
As well as a wife, parent or partner who can pay the bills and then some for the first five years while you grow your reputation and pay for your start up fees and dues.
Every community has a certain percentage of floor owners who will pay to have them cleaned. Is there room in your area for another?
The amount of the above listed qualifies that you possess will dictate your market share. The more you are blessed with, the higher the caliber of the client base that will naturally develop for and around you as your skill set, and reputation grows.
Be aware, most of us cleaners go into this because we're unhireable and the entry cost can be extremely low.
and most of our industry never makes much more than minimum wage, with no benefits....
Do a soul search, go with someone else for a few months to see if you like the daily mental and physical requirements, and seek proper funding if all things click..
Best of luck!
oh, and learn how to clean all flooring and fabric types, repair or restore the types you like working with the best, and find a niche that makes you different.
Will if you want this machine let me know soon otherwise I'm going to list it on Facebook marketplace this weekend
Hey all the old idiots on here.
Bawb, Pigmanmarty, etc. This is why I had a trailer and I don't want to hear any excuse otherwise. When limited source of income doesn't allow for an extra vehicle...a trailer always provides a way to get started.
