help cds 4.8 not fully engaging..
absolutekleen
the clutch kicks in at the belt on my trucks engine but the drive shaft dont turn help
Cleaning Professional
can you turn the shaft by hand.??
If you can freely turn it buy hand then that would tell me that the blower is not frozen and you are not having a bearing/shaft issue ....so more then likely your clutch is bad...just because you can see them click in does not mean it is grabbing.....
absolutekleen
i turn the key off and the clutch at the belt drive on my engine is still and key on it is turning but the drive shaft directly behind it is not and i can easily turn the shaft by hand. is there some kind of centrifugal clutch behind the electric one?
I just got your reply thank you seem im going outside to take that apart wish me luck is there a manual on the clutch somewhere?
I don't have one ....maybe someone else might.
