$34 Last I looked
A bargain.$34 Last I looked
Yeah it's $34 a gallon but shipping puts it at $50
This is how you would apply to Groutlines installed on Ceramic and Porcelain tile? Does the product not leave any residue or haze on the til itself?Jimmy
Spray or pour down the fist coat, work it in with the flat finish mop make sure you see all the grout lines go dark.leave enough product on the grout (and tile if it's stone) so it's noticeably wet. Now go pack up your truck or clean something else.
Go look at the floor, if it looks exactly the same and ALL the areas are still visibly wet, your done. More won't go in so don't bother. That's rare though. This means the last sealer used was excellent stuff, or its a vinyl floor and you're a moron.
If you see dry spots then apply a much light amount then the first coat, massage it in again, leaving the grout a little wet, again. Start from the back and work your way out. Remove all streaks and foot prints.
If no one will be home for a few hours you can now leave. The excess will flash off. Open some windows and turn on a ceiling fan in another room, not the sealed rooms or they'll dry too quick.
If they are home and need to walk on the floors, give it ten then blow one of your fans into the room and in a few minutes the excess will flash off completely.
Instruct them to not get the floor wet for 24 hours.
Send or give them care instructions on how to flat mop with a nuetral cleaner.
Welcome to the Cobbslop generation!
Your body, helpers and wallet will thank you.
It seems to me that the glub glub method would be more apt to over apply or puddle in areas, like pouring finish on Vct.As long as it is not over applied/allowed to puddle then trafficked over, then yes no residue.
Cept when ya get on your shoesNot really as the solids are non comparable between the twin.
Glut glug works well once learned and is very fast.
