Aug 2, 2008 #1 L Larry B Guest Is there any fix for a HF that is filling the jug with water and not sucking any chems out?
Aug 2, 2008 #2 Mike Pailliotet Administrator Joined Oct 6, 2006 Messages 117,264 Yep, your local o0r not so local disty should have a repair kit. Two O rings a spring, a ball and some gaskets.
Aug 2, 2008 #3 L Larry B Guest Thanks guys. Had this thing setting around for a year thought I should see if it can be repaired..
Aug 2, 2008 #4 G Guest Guest Yes there is! throw that away and get a pump up sprayer. You can get all the chem you want.
Aug 2, 2008 #5 L Larry B Guest Steve Lillard said: Yes there is! throw that away and get a pump up sprayer. You can get all the chem you want. Click to expand... Its in the trash. I have 2 that work so I really dont have a need for the adjustable piece of crap.
Aug 3, 2008 #6 C Cleannz Guest I had the same problem with my Hydroforce and in the end all it needed was to be stripped down and cleaned. Worked fine after that.
Aug 3, 2008 #7 P Pmatte Guest Multi-sprayer...(so that way you're actually putting chems down and not so much water.)
Aug 3, 2008 #8 F Fred Homan Guest Take it apart and clean it. There is an internal filter on mine. Cleaned it and it works fine.
