If I built the Vortex
adamh
I love the BLUEline 240 waste tank and the 250 (ish) fresh tank the great hose reels but........
I would use a diesel fired heater.
That would get rid of all diverter valves, HX, and most sensors etc. No more problems.
95% of all problems would be solved. You would have a very simple machine with massive amounts of suck and limitless heat. The cost of the truck would go waaaaaay down and maintenance would be next to nothing. The perfect truck for under $75K. Fuel cost would go up but well worth it.
What do you think?
joe harper
Cleaning Professional
joe harper
What do you think?
"ZEROREZ"....I think It ...has been done already... :?:
Bob Foster
If I built the Vortex I would keep the roll up side door and throw the rest away... and I'm dead serious.
dealtimeman
Everyday is Saturday.
Michael
i would still like to have an option for a conventional hx option for the southern guys who would like one, but you are right a lot easier setup but most guys will not like to fill up with two fuels.
dealtimeman
Michael
read too fast didnt see the diesel fired part thought he was talking about propane. :roll:
Ryan
FCC said:
I'd do the same.
Probably focus less on weight distribution, bling, and using the entire canvas as a "mobile cleaning plant" ( I realize there is still a lot of room but...)
Probably an isuzu IPU, twin mid sized blowers, and diesel burner.............but thats just me
Dosn't stanley steamer have a patent for twin blowers? Or you mean run a wand off of each?
Carpet Cleaning Fool
What do you think?
AMEN Brother!!!
Who's ever idea this is should have their fooking head examined:
I'll take the heat system out of this old rig anytime!:
It seems like a no brainer for a big truck that's already hauling 30 gallons of diesel. I'd much rather PM some soot off a few coils every few years vs. the nighmare associated with big HX designs. Besides, who cares about exhaust? You're already blowing smoke from the pto anyway.
It took nearly 4 weeks of down time just to get one single component of my big HX system repaired. And I'm still not done!!! thathurts
Imagine how simple the repair would have been if they'd tee'd the main fuel line to an igniter, squirel cage, jet, and a coffee can with about 20' of SS coil stuffed inside... No, no, no, that would have been toooo easy!!! Instead, I'm troubleshooting things like engine vacuum, boosters, diverters, breathers, solenoids, thermostats, probes, 3 sets of HX's... etc, etc..
Fooking a$$holes!!!!
What the fook are you thinking?
That's why my next truck might be a ZeroRez or a Duane Oxley http://acceleratedtruckmounts.com/.
FOJL
I have a 440k heater. Brutal heat. Seldom need it.
Of course kero units have maintenance issues too. Flow switches, thermostats, ignitors, and filters.
Thanks,
Lee
Art Kelley
95% of all problems would be solved. What do you think?
I love the simplicity of my White Magic HX system with heat from the radiator and the blower exaust. No problems no maintenance for the last 7 years. 240 degree heat. No way would I be comfortable driving around with a bomb in my van. And with my carelessness there is the chance I would be pictured in an issue of Bane's CleanTimes sobbing next to my burning van. Not worth the risks for a few extra degrees.
Loren Egland
Loren Egland
One good thing about that idea is that you won't be driving around with a bomb (gasoline) in your truck. Diesel doesn't explode, just burns.
It is very easy and cheap to simply keep a burner transformer & flow switch on the truck, take 10-15 minutes to change it when in wears out, than to be down a long time.
Only one fuel if running a diesel engine.
If carpet cleaners where only than sensible.
PS:
what kind of silencer is Under that Mailbox?
So the blower air goes UP the cinderblocks and doubles back down the outside walls and out the floor?
ghostrider
Greenie, there is no silencer, just the coils and yes that is how the airflow is.
ghostrider
Greenie, the silencer is before the mailbox, the air comes from the blower, through the silencer , into the mailbox, up and then back down through the floor, sorry thought the previous post might confuse someone.
Zee
Thanks,
Lee
That's right there my only problem with the diesel burner. that stupid flowswitch underneath the burner. Every time i have some scale junk getting stuck inside the flowswitch, I'm "running for my life" and my "truckmount's life" to turn off the flame!
It should be only burning full force when water travels thru the system. If I don't hear the burner going on and off during work, I'm stressing about the flowswitch getting stuck and keep burning< therefore raising the pressure inside the system and eventually blowing up my heater!
I do descale my unit every couple of hundred hours, but I can't seem to prevent junk build up and sticking the flowswitch.
I don't run chems thru the system except for the liquid judson O2 rinse. That should not cause any build up.
Water softener is not an option right now- i don't have enough room in the van. Unless there is a miniature water softener (like the "waterstick or whatever)
Sorry for hijacking...
floorguy
Doug
Zalan Szabo (zee) said:
[quote="Lee Stockwell":14m6djnb]I have a 440k heater. Brutal heat. Seldom need it.
Thanks,
Lee
Sorry for hijacking...[/quote:14m6djnb]
for me when the flow switch stuck, the thing just wouldnt fire(maybe a fail safe on mine) but i would have to go out and play toggle hockey to make it work for a job...what a PITA...
new flow switch, and bam back in biz baby
Hoody
Steven Hoodlebrink
Bowling Green, Ohio
Role
Years of Experience
21
I've seen Doug's truck. That heater is insane!
Thanks Chuck.
Now you knew this was coming.....
Obviously you are losing some potential heat from the silencer, why not run the blower straight to the mailbox and then duct to a silencer after....seems you would have gained a bit in the sound attenuation as well assuming the mailbox is insulated to some degree?
Loren Egland
Loren Egland
[quote="Lee Stockwell":3i70fr4v]I have a 440k heater. Brutal heat. Seldom need it.
Thanks,
Lee
Sorry for hijacking...[/quote:3i70fr4v]
That must be a different set up than the Powermatic. I can remember it getting stuck once or twice over the years, but I could easily overcome that by using the warm up valve and cracking it open a little to keep the flow high enough so as not to over heat until I could replace it. But to have this happen every couple hundred hours would be very frustrating.
Bob Savage
Bob Savage
For those who have out of control heat happening, on occasion, you need to install another high heat limit safety device to shut off the burner.
I would think the thermostat would keep the burner from staying on if there is a malfunction, unless it is the thermostat malfunctioning.
They aren't!
You have to give kudos to thermostatically controlled fuel burners, not having a flow switch is one less thing to worry about, and probably why you will always see little giant style heaters in the industry, they just plain work.
Zee
So how is the el diablo doing it? It does have a thermostat and a flowswitch, and it still burns without having the trigger pulled.
The pressure builds up sometimes to 1200-1300psi because of the flame being on! If I turn down the thermostat it turns off the flame, and that indicates a stuck flowswitch.
If I pull the flowswitch out and clean it a bit, it works fine again.
ghostrider
Thanks Chuck.
Greenie, you do have a valid point however what you made up in sound attenuation would be lost by dupming to atmosphere after the mailbox, think 6008 and early 7000 trucks
