Lubing blower
Josh Almanza
Josh Almanza
I have a Prochem Legend should I be using WD40 or a synthetic lubricant to spray my blower at the end of my last job?
Since Keith is not responding right now, I will say wd 40. You are not lubing the blower. You are merely displacing the moisture that may have accumulated on the blower lobes. You only need a short burst, then let the blower run a few minutes to burn it off. Too much wd 40 or other spray lube may damage your blower in Keiths (able one) opinion and I agree with him. Your blower is lubed by the oil in the crankcase, not by spraylube.
Sierra Clean Care
Use LPS, TKX.... wd 40 is garbage. DO YOU WANT TO RISK YOUR LIVELY HOOD ON SOMETHING YOU CAN BUY AT A CORNER STORE?
Sierra Clean Care
The WD stands for water displacement. Been around for years and works great.
Actually Ron, if anyone does a search on it, it was invented as a solvent, NOT a lubricant. My TM guy, says, ‘NEVER use wd-40...’ he’s got 28 years, rebuilding TM’s... the product I suggested is DESIGNED for industrial lubricant/water displacing..... I have seen pics, and heard stories.... he, and another VERY well known west coast TM guy suggested I use this product.( Darnell from DK, Chris L. Both from Van.). Oh, AND, Cleanco suggested I use this product as well in the manual.....
Kroil oil doesn't leave a build up like WD40 does. You can get it at Wal-Mart or other places but cheaper online. EBay or Amazon.
It's more expensive than WD40 but a better product.
http://www.kanolabs.com/
Oh look it does mean water displacement
I like what Ron said don’t over use it!
I’ve never lost a blower on two 405 and wd40 on both.
Over 16 k hours and both are still spinning hahahaha.
Sierra Clean Care
I worked in heavy construction for 18 years. WE NEVER USED WD-40..... believe what you guys want, I will use the professional stuff, you guys use what you want.
Never lost one either but have you noticed the residue attracts dirt to it. :errf:
Reactions: steve_64
Sierra Clean Care
Oh, really? Hmmmm...
Can anyone say ‘SOLVENT’.... answer me this, if a guy does a search, can one not also use WD-40 as a product TO DISOLVE CERTAIN STAINS/OFFENSIVE MATTER FROM CARPETS?..... eg. play doh, etc...... ( of course, no one here has ever used, or heard of this method)????? SOLVENT......
could be, I'm not an engineer. I have used wd40 for years and never had a blower fail. Too much of any spray lube apparently can get into the bearings and displace the grease and cause premature failure. Just repeating what I've been told but seems to make sense to me.
I'll spray mine in the middle of a job for extra vacuum. I use a lubricating oil and sometimes a lot of it.
You have to have a solvent to displace water.
FOJL
Much ado about nothing.
You can spray chocolate milk, PBR or other urine substitutes with virtually the same results.
Then chase with clean warm water and allow to run for 5 minutes to dry completely.
Blowers don't fail from "unlubricated" lobes.
Blowers DO FAIL from lack of oil in the gearbox, ungreased bearings, solids and trash ingested thru the vacuum inlet, overheating from vac relief blockage, and blockage downstream of the blower. Excessive side load and similar installation error kill a few.
bob vawter
Grassy Knoller
bob vawter
Boy am I tired of this argument. ...
Warm water with a good dry out afterwards
Morons
Reactions: Dolly Llama
on a hot blower that's been running awhile .
I'll note, prob'ly BAD idea if you have blower HXers .
cause the mud/crud/gunk that's cooked/cleaned off the lobes with plain ole water will end up in the HX'er
bob vawter
Grassy Knoller
bob vawter
On a properly built TM.....
That's impossible. ..
bob vawter
Grassy Knoller
bob vawter
That's what I'm sayin....
Man...nothing gets bye you does it....
This is what my rep from a truckmount department of a corporation told me
“Spray wd40 in it for 3-5seconds when the tm is at full throttle under load (vac hose blocked). Leave it that way for 20seconds to burn out the wd40. Unplug the vac hose, turn down throttle for 2min to cool down the machine and turn it off”
Do this at the end of every day the tm is used.
Lubricating while it's running reduces heat and friction allowing it to spin faster with the same HP.
