Need convincing that OP/ VLM works?
Has anyone tried the new battery powered Vibe? I might get one just to play with. That would give me 2 Orbots and 2 TOPS, and 1 Cimex.
Darcie's Scott used a battery generator to power his pad machine.. God damn genius.. Makes sense for certain situations..
View: https://youtu.be/wrIc3lwwi-M?si=iad0dlseNP6fZiQS
Ever-Fresh
Jeff Paton
Probably does. sic wheelies!
He is probably the inventor of this tricked-out race car!
Why didn't I think of strapping a solar generator to my pad machine? It's only 1/2 the size and weight of my machine!
It seems a bit extra but I suppose it would at least be worth trying in a situation where the core would be a pita…f you happen to have an electric generator laying around
Reactions: Ever-Fresh
Ever-Fresh
Jeff Paton
I could say that this is innovative, but Tesla owners have beat him to it!
Not a bad idea, but why strap it to the machine when you could just run a cord like every other generator?
That ranks up there cleaning the Bane Clene way😬 And I like it! Rig it baby!
Are you fellas aware that Orbital equipment is categorized separately than Oscillating in the Janitorial world?
Meter Maid
The Undetective
In some cases. The potential for fiber damage escalates as contact pressure is increased. I remember when some machines had add-on weights, usually for VCT stripping.
I’m not talking about that level of head weight. The Obot without weights has 38 pounds of head weight on a 15 or 16 inch driver. That’s less head weight per square inch than an Oreck Orbiter.
Orbot doesn’t recommend the weights on carpet because they use pretty weak motors.
I've cleaned hundreds of thousands of Sqft of CDL with the Vibe without weights and with weights. The motor is anything but weak. Not sure why you are stuck on that. Maybe you got a bad one. Or are you trying to ride it like a Lark Scooter?
Meter Maid
The Undetective
Not weak on commercial.
Now Damon … you KNOW he’s going to say that you left it out in the rain.
Meter Maid
The Undetective
It does suck that the hardware gets rusty. I just spruce it up with some WD-40 every few months.
