jeffexe
- Feb 16, 2021
- Name
- jeff
Sorry Mike. I would never buy that. Just wanted to see what everyone had to say about it. My vibe replacement will be the Trinity.Fred doesn't allow people to just drop links without instigating some sort of commentary so I'll take care of it for you, that machine appears to be essentially a stripped down Orbot with the least amount of OP travel possible..
With the biggest drawback being a shower feed versus a spray system which with orbital action is as messy as can be...
And uses 2/3 more solution.
absolutelyYou knew Mike would pop-poo it
The bearing will poo poo itself when it rust or corrodes from that shower feedYou knew Mike would pop-poo it
Obviously you wouldn't use it through a padI can't see a drip feed being very effective. With a shower feed brush, it comes right through the holes in the brush. With a pad, how long would it take to penetrate the pad? The Phoenix sprays evenly ahead of itself.
Yet, people do.Obviously you wouldn't use it through a pad
Thrown in the dump?The ole 175 swing continues to sit on the thrown.
