OK chemists, thoughts?
Perhaps one of the chemical gurus could test different rinse agents to see if the polymers get removed from the carpet during cleaning.
My biggest worry would be how well it actually rinses detergent and soils while supposedly protecting
Reactions: Jim Williams
and you think the dye blockers magically find those little tiny holes and latch on before the rinse gets vacuumed out of the carpet? ...come on Sam you're smarter than that..
I hope.
Have you ever spilled koolaide in a carpet that’s not protected and cleaned it immediately?
Come on whose smart?
If you were prespraying a polymer and rinsing with a polymer I'd give it a solid maybe
but seems like that would be a lot of wasted polymer..
DAT
Bill Cheryl
I just wanna clean like 1%er and make money and not worry about prespray for rest of my life...
I wonder how much more money a carpet cleaner would if they gave their biz more attention instead of debating the best prespray on the planet on fb... Ill just use what mark is using..
Prochem came out with quart bottles of stain blocker in the late 80’s after stain master was out.
It was a clear dye $10
A quart for like a 1000 sq ft.
They sold it for a month and DuPont had a fit.
Finally they came out with master series with the test kits. And two types of protector one for non stain resist carpets and one for stain resist carpets those products retailed for around $60 per gal
If your market allows you to run 1 prespray then maybe?
not knocking Marks product as I've never tried it and he definitely comes across as caring about what he does.
But I carry 3 presprays for carpet and 3 rinses
Reactions: Cleanworks and DAT
DAT
Bill Cheryl
I carry about 3 as well. One for wool, one for normal traffic and one nuclear prespray.
Marks products is very good. I like Harvard products as well which he works with, i think. Prochem definitely is definitely good products. Im starting to lean on what sooper been saying, it aint complicated, you only need a few cleaning chem and it more than enough to do 98.96754% of the jobs...
It was funny so I won't make a list..........
Premium means not having to deal with synthetic dyes
New review for Connoisseur Carpet, Tile & Upholstery Cleaning
Gardnerville, NV 89460
Jeff C.
ZSZ4vJ91NFRSfGglZloERJ4mTd6U0FMmUPOjcGDu6iNsDamILNuVXs-DbN3Fgb9PEdN3Z5VOs1secaFLRrBpG-8M-NF046JjMgh-tsq00feKGaQdUxk1xhjh-D4GEgdaij8tFNHtYg5uPmFKbEisOnLuM3x-QwrmghCFjebuYooeMZjA=s0-d-e1-ft
0
ZoGLx7ktR8B0QPMiQFmHJGgjJQZWWuUE0zd2kox__HNUev9QFa1rAWWk-Oqtx-s5EhLFJHiJt3mD8p8IcytRIWrSV906PsMyRSIrLWaY4kZca92Nsx0TQF5TjUtPRABV7MoZSS6-LbKADwNFqEjZL955zerZJ3RPh_qgS24wwVErFV8=s0-d-e1-ft
1
Paz39CKLyzkP0KGceXhTKSOgTDqPa6vh9peOFrLSnnpPHgyaHiGgHC0G_h8jtmAnVEAh0cg_pkgSnCFrYSEbg9KcxeOdBVdzt0_qMwST_uUphohmRQ_Gj_NweDvAyXMeklG3Yr1svc_LYH45y-4nkLLtciahyIVYxZ3hAqo1YxvCQw=s0-d-e1-ft
0
5 star rating
7/8/2019
So, one evening our dog woke up from behind my tv chair and squeezed out under my small round chairside table...upon which was a crystal wine glass full of RED wine! I watched it in slow motion shatter against the wall and explode against the tv chest, spray into the hall and soak into our nearly new light gray carpet. We did what we could to dab it up, and the next day called Mike at Connoisseur Carpet & Cleaning. We had little hope either that the carpet could be saved or that we'd see anything of Mike, a stranger to us, for a day or two. WRONG! Mike came out within three hours and had it totally cleaned in 45 minutes. It's good as new, and we've found a knowledgeable, trustworthy, professional to call in the future. Highly recommended. Thanks, Mike.
it works .
I used Steve Smith's PBX for awhile as pre-spray and my regular rinse (1/3 to 1/2 suggested dilute of Prochem Heat Wave or Dry Slurry)
The lack of re-soil was noticeable in some homes
it is.
as most is rinsed out in the wanding.
But not all if using pre-spray in sufficient quantity for moderate to heavy soil conditions (gal RTU pr 200-300sf)
Mark Saiger
Mr Happy!
Mark Saiger
Harvard does not make the chems here being asked about.
I believe it was a Steam way product I had won many years ago that also claimed had a protectant in their rinse... But I never tried it way back then...
I prefer not to run a polymer rinse through my truckmounts as in some experimenting we found they would plug up the units especially at higher heat.
I have used a polymer rinse once on a bad powdered carpet deodorizer job... Seemed to help but Descaled after that job.
I prefer (and so does Harvard) to apply a protectant that old fashioned way yet (after cleaning)
It someone could get some product it would be interesting to see it's performance... But I would only practice on an old scrap sample or your personal home vs sell magic pixy dust protectant (@Jimmy L influenced here) to your clients...
Ya if bought it I would try at my house first.
I’ve seen this product for over a year in Facebook. Not a fan of rinsing with a polymer either.
Prochems all fiber deep clean is a good product a acid side detergent with polymer also.
Hard to see but this carpet was rinsed with clean and protect and there was noticeable water heading from pre spray and rinse again.
Maybe buy a gallon and test before you say stuff is misleading or doesn’t work.
making bad judgements can cost you credibility.
But good testing and not theory can establish reliable judgements.
Now go drop some water on an uncleaned area....
We cleaned it all yesterday, I was surprised it was beading you.
my guy dragged a wheel chair and possible burned the carpet I was trying to get the line out. But there was definite beading so it does have protective qualities.
I personally wouldn’t charge more to use it as a protector, I’am hoping customers notice that carpet aren’t resoiling as fast and say wow these guys are great!
Reactions: Hack Attack
Loren Egland
Loren Egland
A lot of short sighted carpet cleaners resisted Masterseries. However, we would mention the product on the phone when speaking to potential customers (must be trained and certified, die blockers like DuPont Stainmaster, two-step process with dieblockers incuded in the cleaning process and then more product applied and brushed in, special costly sprayer required, etc.) and this often tipped the scales to choose our cleaning company over others that didn’t offer this new advanced technology. Masterseries added nicely to the sales ticket.
It didn’t seem to beed up as much as straight Teflon, but it did offer die stain resistance. I once just rinsed out a red drink stain on a white carpet I had recently treated with Masterseries.
