Old guys and their sticks
Rob Grady
Rob Grady
The two pusher holes have stripped threads, I'm thinking die grinder when I get that far, then puller to pop it off.
I spun it up with the new speed control with no load and the shaft runs smooth.
I'll probably just convert to Aqua-Tech drive shafts and waterpump/blower combos in 45 &47 configurations.
bob vawter
Grassy Knoller
bob vawter
Leapin Lazarus .....that sucka is WELDED on...
what now Mr Smartypants???
Reactions: Rob Grady
Rob Grady
Rob Grady
I'm wondering what the issue was in the first place to warrant welding the pulley onto the shaft. There is not enough clearance to re-tap the pulley in place, so I will have to have someone do as Lee suggests if I don't decide to just swap for Aqua-Tech shafts.
Thanks guys.
FOJL
Probably welded on the end because it seemed "loose". Get the weld off and the pulley will come.
bob vawter
Grassy Knoller
bob vawter
Thanks guys.
A case of dumbassedness!
