Questions about VLM
Lc17smp
Larry Cole
I have a chance to get a few large VLM jobs. Having done HWE on medium sized commercial jobs has worked so far but will not work for this property. Walked one of them today and its not possible to use my truck mount. Ive read pretty good reviews here about the Orbot Vibe and I may be able to pick up a used one locally for decent price. A few questions. Still a good enough machine? How many sq ft per hour should I expect to be able to clean? No offices or stuff to move. Mainly hallways and open rooms. Light to medium soil level. How many pads should I expect to use per 8 hr day? What pad should I be looking at getting? I never expected to go to the dark side, yet here I am. The money would be very hard to pass up on this.
You should easily be able to do 2000 sqft per hour. I would use microfiber pads. I prefer an oxy encap for most of my work but bring a solvent based spotter for greasy spots. Conversely, you could use a high pH encap and bring an oxy spotter for coffee or beverage stains.
Buy the Orbot for sure, and look for a Cimex. They are the King on those type of jobs. I spray spots a little ahead of me with Top Spot and use an oxy encap. It’s an awesome method on large commercial.
SteamwayPro
George
Nope. Previous posts are misinformation :biggrin::biggrin::biggrin:
Call or email Tanoah at Excellent Supply
tanoah@excellent-supply.com
1-800-330-1888
Buy a new TOPS Phoenix, get a case of Releasit DS2 and Microfiber Bonnets. That is the best combo for cleaning CGD
You're Welcome !!!
Will she be able to gossip about folks in the industry like Mikey would if he called him instead?
SteamwayPro
George
Opinions are like assholes and elbows and everyone has one! Excellent Supply is excellent and they are my go to. I’m pretty sure they will agree with my method.
Cimex is a great scrubber but that's it. It doesn't remove any soil unless you post vacuum
I bought a new Cimex about 12-13 years ago used it once and sold it. All the coffee stains came back because it put down too much solution. It wet the carpet too much. I don't consider a Cimex low moisture cleaning. It uses too much solution. Of course I would have gotten better and learned how to use it better if I used it more but I didn't like it. Plus it's TOO big and TOO heavy
That’s too bad for you. Too bad someone didn’t show you how to use it. You can control the solution output like a foot pedal on a car. Who said anything about not pre vacuuming. The Vibe can be used for post padding if you have both. It’s certainly not misinformation.
Reactions: AlienAgent
SteamwayPro
George
Excellent Work !!!
I didn't know you followed Cimex with a Vibe and bonnets
Instead of a Cimex I now have a 20'' Whittaker Trio that I use to scrub first and follow with Phoenix and bonnet. I don't do it that way on every job. Sometimes I will use a fiber pad on Phoenix instead of Trio.
Trio is definitely VERY LOW MOISTURE cleaning. It puts down a fine mist in front of 3 brushes with 75 pounds sitting on top of the 3 brushes. 15-30 minute dry times. It's a excellent scrubber
Churches are notorious for coffee as you know I’m sure. I use various methods to get the results needed. I use Brush Pros with renovators a lot to prescrub. A lot of times I’ll
start with spraying the coffee spots and use a 15” crb. Sometimes, we don’t have to use the Vibe. I use porty’s or truckmount. Whatever I feel like and is convenient.
Reactions: SteamwayPro
SteamwayPro
George
If he can't afford a new Phoenix, the Vibe is still a decent machine. A little slower but will work. I've never tried DS2 but Saiger's Code Red of Encaps works great for me.
DS2 takes out coffee stains with no problem and brightens carpet but doesn't have peroxide. Plus it cuts through grease. DS2 is made for cleaning the types of soil and stains found in CGD.
SteamwayPro
George
My first OP was a SprayBorg. I bought it when I first started experimenting with VLM 15 years ago and still have it
And I have a Tankless Vibe that I use on big residential so I know Orbot makes a nice OP
I bought that malish driver in 2015 for the SparyBorg. It makes SprayBorg/Vibe much more aggressive and digs deeper on residential carpet. Hated the velcro driver
I have both the Sprayborg and the Phoenix. I should get the updated driver for the Sprayborg. I agree with you on the velcro driver. Although both are well built machines, I find the Phoenix much faster and a little more aggressive.
SteamwayPro
George
I agree Phoenix is faster and more aggressive. I only use it for commercial carpet cleaning
I add weights to Tankless Vibe to make it more aggressive on trashed residential
encapman
Rick Gelinas
We have a little trick for coffee spills that works 100% of the time...
View: https://youtu.be/imtgi__PaJs
Lc17smp
Larry Cole
Well thanks to the advice and encouragement I got here I am moving forward with expanding my biz into VLM. Or is it LM? They want to to start asap and I am going to buy a used Orbot Vibe locally. I may have ordered a new Sprayborg but they appear to be 4-6 weeks out or more. Going to make a few calls in the am to verify. For those of you who do large cgd jobs I have 2 questions.
What pad ( bonnet) and size would you use for this cgd? (Link to purchase?) And how many would you use per day on 1 machine?
If it's all in that condition...
You can buy these from me or Rick but Direct Mop Sales is the imposter..
500 sf per side on that floor.
19"
If there are worse areas you'll want to pre scrub it when a brown 3M Fiber Pad, use the microfiber than follow up with a Glad Pad, which is a cotton blend that absorbs that gunk that the MF won't...
Both are here in 21"
I would start with the 19 inch microfiber pads. On light to medium soil, you can get 400-700 sqft. You can use both sides of the pads when new or newish. Once they get too floppy from repeated use and washing, I usually only use 1 side.
Reactions: hogjowl
