Re-stretching carpet
Evets
Installers around here charge about $3.50 per yard for installing, plus pad, plus tack strip, etc.
I'm thinking about $2.50 per yd for re-stretching. Does that sound about right?
This price would not include moving furniture.
Evets
More money.
Thanks Lee.
I've got the skills, just want to pass them on to my son and make sure we're charging enough for the service.
I started working with an installer when I was 14 years old. Damn, that was 45 years ago. (I'm not as young as I look - lol)
Way too much. All you are doing is restretching. You're not cutting the carpet to fit, installing trim, installing new pad. I charge $90 a room to restretch.
Fat Mike
Mike G
$2.5/yd is cheap a 12x12 would be like $40
depending your area i guess. your minimum should be way higher than that imo.
Fat Mike
Mike G
I charge $150 Minimum for first room, $100 for any other areas. Reseaming is strongly discouraged.
Big bubbles, no troubles.
Can not compare to an install. Higher risk to repair the laziness of others.
plus being able too figure out why it failed. sometimes laziness but not always. i've found water damage and actual current water leaks, termites that rip tacks to swiss cheese or customer fault(being away from home all summer without AC on) not everywhere but huge difference in the desert
Reactions: Walrus Gumboot
95% of the time, not being power stretched in the first place.
I try not to open seams if at all possible, but sometimes in halls with multiple rooms connected you have to.
I got that, Mike
My hED scratcher was at Damon’s reply
“$2.50 i way too hi”
But gets $5 bukz a SY on a bed room
:headscratch:
I still think thats too high. 140 sqft bedroom needs a stretch. $350 to charge to stretch that one room seems like robbery. I’m happy if I get $90 for flopping down my power stretcher. If i ned to reseam, i add on $50.
Evets
Damon, you keep confusing sq. yds with sq. ft.
Fat Mike
Mike G
$125/area sometimes ill drop to $100 if i have a lot plus furniture
:headscratch:
is it reading or math you're deficient in??
at $90 per room, you're at $5.60 sq yrd
$2.50 sq yrd, which you said is "way too much"....is forty bukz
FRR
Reactions: Charlie Lyman
