Removing air filtration lines?
P
PTMatt
Just looking for some good methods to remove filtration lines. What have you found to be the best chems & tools for these jobs?
Mountain View Carpet Care
Cleaning Professional
P
PTMatt
Going to try and pick some fels Naptha up tomorrow.
If a house has filtration lines throughout, how do you charge? Do you include their removal in your original price or do you charge separate? If separate how do go about prcing?
Thanks for the input.
steve frasier
it requires special attention to remove so charge for it after you point out to the home owner that it will not be removed with normal cleaning
any of the 3 mentioned products will work, some rinse out easier then others
Filtration is the playground of Judson Magic Bullet encap spotter....and it won't be prone to resoil like so many others.
Buy a quart, mix 1:1 with water and lay it on, rub a bit and rinse..you will trip out.
Steve Lawrence
Steve Lawrence
We've had good luck with Cyclone HWE and an internal jet crevice tool from PMF--so much better than hacking it with a wand or furniture tool IMO.
tim
havent tried judsons, love cyclone for black greasy spots but fels is hands down the best filtration line cleaner i have tried. I lay down some water with the wand, rub in the fels naptha, aggitate with a carpet shark, rinse and collect the check.
Blue Monarch
Dirk Wingrove
Anyone have a good pic of filtration soiling under a door? I want to include it with an article I'm writing.
Zee
Vac it real good, and apply the chemical you settle with. I have very good success agitating with the grout brush with long handle- its great along baseboards.
D
DCS.LLC
Filter Free, the best thing I've used for that and many other stubborn stains. I use a terry cloth towel and work them by hand. A good pre vac goes a long way. I include this in my service(price)but my price is a little higher than others in my area.
P
PTMatt
Anybody try Filter Out by Prochem? It's the only thing my local supplier carries. I'm hoping I can find the Fels at my local grocery store.
Nate The Great
Store locator. I typed in zip code 95661 and found a lot of stores carry it. Look up you zip and see which is closer for you.
Brand Select a brand...Laundry Care
Select a product Description...Fels Naptha Bar Soap 5.5oz
zip: your zip code
http://www.henkelna.com/henkel-store-locator-9949.htm
