side by side Powermax to S&G..not much to show
Ruff Hewn said:
S&G mixes better (cause you don't have to mix so much)
PM smells great
the thimble full pr gal RTU of S&G in unrealistic imHo
The mega dose larry suggests is more than is needed
so I've been mixing S&G at 2oz pr gal and Cobby's at 4.5 oz pr gal
that makes them "dollar for dollar" RTU mix
it's a draw .
neither out preformed the other at those rates on moderate soil conditions .
They were both very good
Your "equal cleaning" mixing ratio is 4.5oz./2oz = 2.25
The cost figures I've seen published, indicate higher cost of 256%.
That would indicate 14% more cost-effectiveness for the PowerMax.
We also think the "customer acceptance" of our new fragrance is important.
Larry
The only flaw in that, is S & G works great at 0 .5 to 1 once per gallon. I am using them both, and love them both, hard for me to pick a favorite. I love how pwermax eliminates almost all spotting, and I love how S n G melts greasy traffic lanes like butter.
XTREME1
RIP
Greg Crowley
My main prespray is Powermax but I do like slop and gobble scent MUCH better
Giorgio
Giorgio
i'm going to put both pails on the truck today and see how they stack-up performance wise.
Goomer
Frank Mendo
Marty said:
The one scoop per gallon suggested dilution rate for Slop and Gobble is unrealistic. It might work for a slightly soiled situation, but who uses a nuclear pH prespray on a lightly soiled carpet? At 2 oz's (or scoops) per gallon, it is a fine prespray. I have not, however, had an opportunity to test it on a greasy restaurant yet, and hope I don't for quite some time.
Which scoop you talkin bout??
The small scoop that comes with SG is 1 tablespoon (half ounce) I believe, so 2 of those scoops is only 1 ounce, not 2 ounces, and 1 ounce is the higher recommendation from Les.
Maybe 1 scoop (.5 oz) may be unrealistic for trashed, but I have been working through a tub, and not going over 1oz per gallon and it has kicked ass so far.
Still well below most other products and mixes REALLY easy.
I think most that have used both will agree that they are both great products, but I am mainly interested in the lower dilution of SG.
I am not sure cranking both up that high is going to help the test or not.
Mix any sledgehammer that strong and anything will come clean, I think it's using less that let's you see the difference.
I get incredible results each and every day at one ounce per gallon of SnG.
Toss in some Oxy Clean if you really want to see the shit hit the Dripod
What's the point you are making, Juddy Baby? I ain't going to re-read that whole thread.
Eric Valentine said:
[quote="Mikey P":bt8df80w]Toss in some Oxy Clean if you really want to see the shit hit the Dripod
You use Oxy-Clean in your prespray?[/quote:bt8df80w]
Yes I do.
I tell Mrs Pift that the blue crystals are the scOtchguard
I use Oxyclean on tile and grout, so I keep it on the van. I have added it to my prespray before and saw absolutely no additional cleaning power from it.
I'm think I either have an exceptionally wonderful prespray that can't be improved upon, or adding the Oxyclean is another "buy a Vortex" bulletin board fad.
