I wouldn't buy another problem if I were you.That is a good deal with a new engine and transmission. I'll check it out. Thanks Dwain-o!
You can find a better deal than that.
Idk, I can see both sides. Frankenstein has had the engine & transmission replaced and he gets exceptionally good treatment. While setting at idle inside my shop without any warning spun a cam bearing while idling!, not screaming down the road @10,000rpms! Idling. Fortunately for me the new engine was covered under the factory powertrain warranty. 8 months later again without warning while driving down he lost 3,4,5 gear clutch pack un Fortunately that wasn't under warranty and cost me 7000.00 thats just the way vehicle's are built these days. It doesn't seen to matter how well you care for um if the factory produces a pos. Frankenstein is a 2020 with only 58k the oil gets changed between 3-4k(when ever the computer says) transmission fluid was changed twice(now three times)rearend changed once brake fluid changed twice powersteering fluid changed once. I drive it as if i have to depend on it for the next 20 years. So to dismiss this by saying that it wasn't cared for well that may or may not be the case. Lack of care or maintenance may not have been the problem, that doesn't seem to matter anymore. There was a time it did. Supposedly when you get a rebuilt they are better than new because the factory defects/ weaknesses are corrected the transmission shop(didnt do the rebuild rather installed a rebuilt)pointed out the clutch problem fix and potential torque converter problem and automatic upgrade included in price. So we'll see. When I bought my van it was 1½years old with 22k on it. Its a 2020 chevy express 2500 extended with 6.0L first sold new in 9/19 i bought it in 12/21 with 22k engine was replaced 8/24(5 weeks left on 5year 60k powertrain warranty) transmission replaced 3/25 approximately 53kI wouldn't buy another problem if I were you.
