wax on wax off
bob vawter
Cleaning Professional
Grassy Knoller
bob vawter
Welcome to the 21st century :clap::biggrin:
Yep.....check out nano technology. ...
Geeeez.....i gotta tell you guys everything?
Google it!
It'll give yor floors that wet look...
The atoms that make up the wax are actually smaller than the atoms of the surface. ..
Therefore imbeding itself deeper into the surface.
Modern technology. ..
If you really want a shine....use ceramic coating. ..way 'pensive but will last 6-7 years....
Already been down the nano rabbit hole, the polishing rabbit hole, and lots of other holes:headscratch: spensive is the key word on anything. Just like mega dollars for tile and grout cleaning, if it ain’t practical, they won’t use it long term. That’s what they hire me for. Keep it looking good at a reasonable amount of money, #please
bob vawter
Grassy Knoller
bob vawter
What you talkin 'bout Clyde...yous ain't been down no nanno holes...
Ok, maybe that was the only way I could of to say, been there done that:icon_rolleyes:
DAT
Bill Cheryl
I don't know but I use a 20 degree tip and about 500 psi just getting it wet pretty much.
I'm no pro just what I'm doing.
That is is cool. That would be soft pressure cleaning. That works, did you do the all the exterior as well?
dealtimeman
Everyday is Saturday.
Michael
You need to burnish the floor uhs to make it pop
Matt B
Matt Briseno
Makes the wax harder too , helps it keep the shine for custy
Andy
Doesn't Matter
Because you have low humidity and doing it in the middle of winter with even lower humidity. If you are doing a sizable floor you have to pay attention to your overlap. If the finish starts to dry before you start your new line and you overlap you will pull or drag the previous finish (it will look terrible). Might not have been technique issue but fighting temperature and humidity.
Reactions: Hack Attack
dealtimeman
Michael
Did you have a lot of cloudy areas or streaks?
Hack Attack
Dan
besides Sams issues :winky: streaks can also be caused through using old product or mixing new and old, some finishes can offgas if left sitting around and the solids dont seem to blend as well.
My terminology or explanation is possibly wrong but I don't like using old product or mixing new and old
Come on you’ve streaked once or twice?
