What accessory type tool would you like to see.......
Bob Foster
Of all the accessory type tools you use or would like to use what tool would you like to see invented or improved?
vincent
Vincent Sapp
Hose reel stop. That way I could disengage my reel and use the stop when traveling or using the other reels.
I think the vortex has one.
Greg Loe
interchangeable head on an upholstery tool. from wider to regular to craves .
A small motorized brush roll on a upholstery tool.
Also the same for a wand where its not too bulky and fits right behind the slot.
H
harryhides
You mean like a Rug Doctor has?
Al
Here's my latest invention
It's a self contained scrubber for stairs and furniture. Use encap to scrub and run or use it to work in your pre spray. Has 3 soft brushes or fiber pads.
Minature battery op electric pump, shoots the spray out of the feed head,
Shampoo foams up real quick, it's like a mini Cimex
AL
[/list]
GRHeacock
I have sold all the ones in the original run, but have more on order, should be ready in a few days. E-mail me for more info.
Gary
floorguy
Doug
whats up with that funky 40 yr old orangeish carpet????
whattaya mean Funky...It's all around us.
funny thing is it cleans up better than todays crap, what does that tell ya!
Jeremy
Jeremy
You use WAY too much Xerion & have rewired your rotary to spin @ 600RPMs!
a type of insulated quick connect that can hold up to a little heat and pressure would be nice
Blew another one of them today
and another check valve...........
I am only 220 at the machine and clean around 400 psi........
A segmented Vac reel where I can keep mt 2.5 on one side and the 2" on the other...
Thom, are you listening?
4
406
i would like to see 2" abs pipe installed in all high rise apt. buildings along with 3/8 pipe for solution, hook up from ground level and have access to each and every floor. all we need to do is take hoses from floor to floor, no more hose in the stair case.
something that could strap on to any shoe to act as a scrubbing device.
some sort of expanding relief valve on the wand......................Gary, how much for that calculator watch!
