What's wrong with the AW29
I see countless videos by guys new and old using the ( best selling) AW29.
I never used one day to day, just out of curiosity..
I still use mine. I put a green glide on it and it went from a pos to a useable wand. I use it mainly with my portables. I like the wand size, great for apartments. I use the mach 12 and a 2 inch westpak with the trucks but the aw29 with glide makes a great back up wand.
Reactions: J Scott W
Way too small for this oaf
Loss of heat
Head too high
Not great recovery
Perfect for my height. 5' 10". Great for getting into tight spaces like closets and small hallways. Recovery is an issue, compared to the mach 12. The glide improves recovery. Just go a little slower or add dry strokes. With a 6 flow, heat loss is minimal. There are a few versions of the aw29. Some are a lower profile than others. Cheapest wand you can buy if you need a spare but it will never be as good as a premium wand.
A hole glide turned mine into an effective wand, but I always pull off the devastator instead.
I moved from the aw29 to the pmf802 internal jet. I was trying to get hotter water
AW29 is one of the greatest wands in the history of the world
But not in the hands of those that blow 450-500+ PSI and "saw" square yard sections with trigger keyed
.L.T.A.
The Greenhorn WAS heavy
But I was a STUD back then
I’m a 1.5 Devastator these days.
Here's a couple of aw29's. Not all are the same. One is a low profile, with the Jets closer to the carpets, minimizing heat loss and enabling you to get under furniture easier.
Reactions: Sierra Clean Care
Jim Williams
Jim Williams
I have the low profile Westpak version. It gets under furniture great and cleans really good with those jets close to the carpet. I only use it in cluttered furniture houses. I prefer the single jet Hydrahoe in open areas. For some reason it feels better to the old back muscles.
20 YEAR OLD 16 INCH CASTEX WAND............WITH A GLIDE!
WOMEN LIKE A "BIG" 16 INCH WAND!
THEY WILL SMILE AS THEY SEE YOU PUSHING AND PULLING THAT BRUTE!
I've got an unglided unused AW29 wand sitting in my garage, it came with a porty 6 months ago..
no idea what it cleans like?
I was thinking of trying it for the occasional cess pit where I refuse to vacuum
