Try the longer black ones.Swivel 1.5s come apart way too easy
using your wand doing stairs, you should get one of those plastic coils that is on your 2 in hose for your 11/2 hose.
You live in the desert.and yet my carpets come our amazingly wonderful and dry in 2 hours...
Doesn't the wand come with a 1.5"-2" adapter?
Using a 1.5 whip will reduce your airflow but will increase the velocity of the air. As long as the whip isn't too long, the results should be the same.So subtracting from the amount of 1.5 hose gives you better perceived airflow.... even though the tapered hose, along with the 2” opening at the head was somehow supposed to be what makes the wand scream.
I wonder if the whole thing with this new 12” is just placebo effect and as it turns out, 2” hose and 2” wands simply produce better airflow, no matter the technology involved.
My 12” inch hasn’t been built yet, so I can easily switch to the 14” instead.
Good info...Using a 1.5 whip will reduce your airflow but will increase the velocity of the air. As long as the whip isn't too long, the results should be the same.
Yeah but your wand technique sucks so it's all for naught, according to Bawb.I got some real flexible 2 inch hose from Olsen last year that is easy to work with.
On my 1.5 inch wands I leave the cuff on them without hose attached to it and the 2 inch cuff slips over that so I run 2 inch on all my tools. It makes a big difference in the amount of water I leave behind.
Any particular reason why you made me watch that?
Don’t second guess your purchase. Also, the way it is bent will let you maneuver around things faster than a politician.Here's to hoping you're right....
I've been using the Bentley... good recovery, but I really have to push the head into heavy pile to pull water from down deep. Could be the green glide I replaced the stainless glide with. Anyway, I like some bite in a wand.
Id go with the 14 inch but too many jets.
-for some reason I would prefer a non swivel wand.
