Best portables these days...?
Yes I have the same one with heat works great BUT wont go up stairs even when I was younger. I talked to them and said to extent the handles higher.The unit I have has 2 3stage vacs and 500 psi. But nothing is perfect .
I have an old EDIC Aquafresh which I use for the odd time I might have to go upstairs. Got it brand new in the box a couple of years ago from a guy who was retiring. Brand new 25 year old machine. Only 100 psi and 2-2 stage vac motors but the beauty of those machines is the folding handle that lets you go up stairs easily. I routed the power cord out the side as it was catching where it was originally mounted. My main portable is an old Mytee speedster with a 500 psi pump and 2-3 stage vac motors. Goes up stairs somewhat but could use taller handles as well.
icleancarpetz
Rafael Samson
You have an Ole Mytee?
Man i wish i kept mine. Best portable ever. Back then it was called Mytee Stinger. Yellow Bumblebee, 2-3stage and if not mistaken i think 150 or 20o0psi. Perfect light weight. Easy handling. Wish i could find one.
Bro, that's basically a Mytee Speedster.. Any speedster without heat should fit the bill..
I can lift it into my van on my own still. I replaced the pump with a Pumptec 217 permanent magnet DC motor. Comes with a rectifier, plug and play. Draws under 3 amps.
