Living The Dream
SorryUncalled for..
Your better than that.
SorryUncalled for..
I’ve been trying to tell the Alabamian inbred that, but he doesn’t pay attentionBut you use the same vacuum they can buy at walmart.
It would add an hour to properly vacuum the average job.
Have you ever wondered what your customer thinks how much they are paying you to vacuum with the same vacuum in their closet?
How many have asked if you use your vacuum in homes with dogs and cats?
Does your waste tank on your van get debris in it?
Do you currently run 2" hose? I think I run a 10' whip of 1.5".So 350 psi chosen wand hole glide behind a good truckmount and good wand technique
= fast dry times and repeats
no just on stairs and upholsteryDo you currently run 2" hose? I think I run a 10' whip of 1.5".
Mike will have much better insight on blower, but I have used my Chosen on my Portable, my Boxxer that has a 47 blower, and my Everest. It performs great with all of them.Would a 45 or bigger blower max out a chosen wand up to 250 ft
I think it makes a huge difference but I know nothing
I did have to look that up you wanker!Malaka
Were you referring to me? You’re right, I’m still on BlingMatt can’t figure Google out
BingWere you referring to me? You’re right, I’m still on Bling![]()
I hate it when mis-spelling screws up a jokeBing
I agree.Because after a lot of back and forth and testing both glides. The dry times difference is minimal at best.
The hole glide struggles to suck up dead moths or similar debris we find in homes. I hate having to unhook my hose to suck something up that my wand should be able to get. And before you make assumptions about vacuuming. We have the customer vacuum, we vacuum, we prespray, CRB, all before HWE.
And if we are saying that slot cleans trashed carpet better, wouldn't it also clean any carpet better?
But, The argument that a hole dries faster than a slot I feel is a bit over embellished.
I do want to make it clear that the Green Glide in any shape is a true asset to any wand. I just happen to have a difference of opinion on which version is best.
My #4 blower produces more then enough air intake to pick up every piece of gunk off the carpet. At the end of each job i send a photo of the gunk from the filter of what was pickup from the carpet. Every client is both horrified and impressed.But you use the same vacuum they can buy at walmart.
might want to rethink that practice...My #4 blower produces more then enough air intake to pick up every piece of gunk off the carpet. At the end of each job i send a photo of the gunk from the filter of what was pickup from the carpet. Every client is both horrified and impressed.
I learned that too. But some request to see it sometimes now and then they ask to see how dirty the water is.might want to rethink that practice...
[ normal] People don't want to be showed what slobs they are.
Yeah, that tooWere you referring to me? You’re right, I’m still on Bling![]()
Been doing it for years. Never had negative reaction. Most add a little tip and appreciate my phenomenal results.might want to rethink that practice...
You’re smart to ignore advice you get here on anything other than tools. And you need to ignore half THAT.
The groove is to prevent lines from the bridges and to create airflow at the end for better edge cleaning and reduce lockdown.Groove, no groove. The groove causes the glide to grab the carpet. Kinda defeats the purpose of having a glide
View attachment 130916 View attachment 130917
The last time I tried wanding on a thick pile with my prochem ti without a glide was crazy hard to doThe groove is to prevent lines from the bridges and to create airflow at the end for better edge cleaning and reduce lockdown.
Many cleaners like the little bit of bite that the groove creates. Our grove is less grabby than others..
Try a glideless wand like a Prochem Ti or Quad sometimes, that tiny bit of grab is nothing...
