- Apr 17, 2009
- Name
- Kenny Hayes
Sketcher shoes and black socks?? JanitorDo you wear that pair of pants everyday?
Yippee!You’ll be called every time now.
Nonixing the fans. No one has time to watch finish dry!!Nix the fans.
So where do we line up to get our share of crow?
I thought propane stripper was faster and more aggressive to strip and autoscrubber for cleaning after it.Auto scrubber yes, hardly anyone uses propane strippers anymore.
I may run a dehumidifier if rh is extreme, but blowing hair all over a freshly finished floor is a killin'-offense.Nonixing the fans. No one has time to watch finish dry!!
Different situation. Original post was about a beauty school, likely to have lots of stray hair that will be spread by fans.Ok whatever. I’ve been doing it this way for 30 yrs. but you drag the dehu. I’ll use Patton fans. Especially when they’re telling you we have mass in 45 min. You learn to dry em.
The directions on the product I use says to let dry an hour between coats. I wait till its dry to the touch or almost before using the fan. It helps with low spots and corners that may take longer to dry.Every coat was dry in under 20, why take the risk?
Is @Willy P Willy in line yet?
